Constant Press.CCS Pads
FourEyes45
I used the search But did not find but a couple of Post..
Can anyone give more info. on these Like or dislike...Thinking about getting a few for the Flex 3401??
Stick with the flat pads or Hydro Tech Pads.
I would stick with a different pad also. I bought several when they were on sale last year and will not be buying any more.
Walt...I agree with other who are saying get other pads. There is nothing really wrong with the CCS pads, it just takes ALOT longer to break the product down while polishing. The cut on these pads are slightly less than flat or hydrotech pads. These pads are open cell pads which will absorb alot more product than a closed cell pad, thus causing pad saturation, which can delay your cutting ability until you clean the pads or switch them out. Granted...the pads will last alot longer than a hydrotech pad-can't say how long the duration is compared to a flat pad as I haven't used those yet, but you'll spend more time polishing with a ccs pad than the others. If you decide to go with hydrotech's, I recommned getting alot of them, and clean and change out your pad very often. This will prolong the life this pad. Hope this helps.
AG has 6.5-in flat pads on BOGO at the moment for $9.99 so you 2 for $10.
Thanks Guys Its always helps getting info.from You...
