After only about 3/4 of my very 1st polishing job, my orange LC flat pad came unglued almost completely (Velcro & foam).
Do you guys know if I can reattach these materials using contact cement? Any other suggestions are welcome, thanks
Maybe just chalk it up to experience. Not sure gluing it is worth it. Cut it into pieces and use it for application sponges.
Thanks Flash...I just think that some how it's my fault because being my 1st polishing job I feel I did not use it correctly or something...yeah I know, I have issues![]()
fyi most upholstery glues are contact cement...and should not melt foam...key words are should not...and yeah that's a manufacturers defect not user error, glue completely came up from pad and no bits of pad on the glue means crap adhesion, call up lc and get a replacement! best of luck to ya
Just an update:
I did contact LC customer service and Eric Dunn from LC is making things right, and he will be sending me a replacement pad shortly. Thank you all for your input.
Thank you LC, I'm a satisfied customer![]()
