Hi guys. I have recently started using a rotary buffer (Dewalt, 8" pads). However I have found controlling the buffer in smooth straight lines very difficult. It's like the buffer has a mind of its own at times and will try and go off in different directions. It will also tend to grip the paint at these times which makes it hard to control it. I have noticed I have the most control when I slightly have the pad at an angle, and with minimum pressure on the pad. On vertical panels I find it really hard to control the buffer! Sometimes the buffer will 'jump' which I assume is due to the pad needing cleaning at these points. I have been using plenty of product too, not sure if that's a problem or not.
Any tips on this would be really helpful!!!
