RE: Small (Med., Lg., X-Lg., Jumbo, etc.):
(Except when someone is brave enough to ask me what size my wife is...
to which I’ll either reply by saying: 5'10"
tall; or,
Firm---as in hard-body firm)
-I think more in terms of
length/width.
RE: Scratch(es) I ask myself: Are they among any of these types, of what I'll denote as "blemishes":
-Swirls (of varying degrees), holograms, haziness, marring, R.I.D.S
<<<(M.P.), etc.
And then I will use:
Depth---How
deep has the top-coat paint-film (for this purpose: CC) been penetrated/compromised...
by whatever means…as a barometer of the blemish(es)-removal-processes, if any.
-In conjunction with a blemish’s
length/width, its
depth will determine the
volume of CC that’s been
removed, causing said blemish to be
"seen". I&J-MHO…It had to go somewhere!
Dependent upon the volume of CC removed…
Can that removed CC be replaced…Or must it be?
-Depending on a person’s skill-level, perhaps:
1. Wet-sand; fill-in/blend-in; or a re-spray
2. Leveling, so to speak, to the surrounding areas; "rounding-over the edges"
3. Using the:
"if your fingernail catches in it"...approach:
Even moreso…just the rounding-over the edges of the blemishes…
4. Other methods.
One such other method may be:
"Spot-Buffing"…by hand or machine.
-Care/caution should be utilized when doing so, especially by hand.
-Being over-aggressive by the user/products/applicator can often lead to less than stellar results.
As such, then...
I can only suggest in your situation (and in order to maintain/preserve as much CC as possible)…
-To polish the
'scratch'…while keeping the:
just-rounding-over the edges/aggressiveness...in mind;
-Then use a light-source to see what degree of 'scattering-light': 'bounces back' to your line of vision.
Too much 'scattering' for your taste…polish a
"little" more (subjective).
If satisfied…LSP it and Enjoy your ride.
Because:
-Unless a vehicle is a
bona fide Show Car, with an undeniable Show Car-Finish…
A person could otherwise go berserk!!
Again...I&J-MHO…
