because the paint is "hard" its ability to flex is diminished. Therefore anything with an edge to it cuts into the paint instead of the paint allowing it to absorb or rebound.
TOGWT - You're a wealth of information! But, alot of your posts/replys are above most peoples (if not all) comprehension and understanding. (please don't take this the wrong way). It's almost like a high school student taking an advanced physics class at Harvard. Can you rephrase and/or direct your posts keeping this in mind. Your message may come out better.
You wrote above that different colors are harder/softer than others. How does this come into play when almost every finish these days are clear coated?
Does a finish with more orange peel have the ability to show off less surface marring because of this peely finish reflecting/refracting less clarity? If so, does this make the OP'd finish more durable in addition?
Ahhhh, a self appointed teacher.Begs the question, do you teach the class to the comprehension of the least able student or do you teach so that each student aspires to reach their full potential?
From your quote I assume you know the answer to the questions I asked, so I can only assume that you'll be equally qualified to answer then? Please do.......Brian Brice said:Very well put.
If you tell me specifically what it is you don't understand about the post, I'll do my best to explain it.
Thank you very much. I'm on the same page. It's intersting to know that some single stage colors are harder/softer that others. Very interesting.
Would you say that a heavy OP'd finish would scratch or marr less/more from day to day abuse compared to a very flat surface?
