ntwillie1
- Feb 1, 2013
- 392
Hi all. I just got my 21ES a couple of days ago and today I finally had a chance to use it. Here are my first impressions from someone that is used to the PC7424:
1. I don't think the rupes is as smooth as I thought it would be based on the reviews I have read. Maybe I am just used to my PC or maybe I am just used to working with my 5.5" pads. This 7" pads are freaking huge. When you first get the machine started its a little weird because of the way the machine throws around. Once it's up to speed it's much smoother. I also noticed that the machine seems to run hotter than my PC.
2. It did do an excellent job at polishing my larger panels and removing water marks and light swirls. I used the green pad and the rupes quarz gloss medium gel polish.
3. The button to hold the trigger in a locked position is hit or miss with me. Half the time I couldn't get it to lock so I had to manually hold the trigger which was tiring. I'm going to have to figure that out a little better.
4. My biggest peave about it is that the quarz gloss medium gel compound I used today is absolutely the dustiest product I have ever worked with. I mean it looked like I had been sawing wood on top of my car.
5. What is the recommended best practice for cleaning my rupes foam pads?
Thanks
Thanks
