cquartz uk question
bguiliano
recently had my car coated. Was wondering if things like the solvent from Dr Colorchip and quick detailer are safe to use on the coating should i need to use either product.
thanks
thanks
I don't believe using Dr Colorchip on a coated vehicle will adhere properly. Should've filled those chips prior to the coating. I made the exact same mistake!
Quick detailer is perfectly fine to use.
Thanks. For DCC I was thinking for future chips
You don't think the solvent used to wipe excess paint away would harm the coating?
I can't say for certain, but I don't think it would. I'd suggest you PM or call Nick. He can give you a definitive answer.
