Cquartz vs mr fix 9h coatings
HU11LK
Interested in comparing the differences between Cquartz ceramic coating vs the ebay Mr Fix 9h ceramic coating
The cquartz is about 20 times the price.. but is it the same stuff?
Are cquartz users paying for marketing, bit more testing and proper instructions.
Is the Mr Fox 9h a copycat but still a bargain.
My neighbour bought the mrfix9h stuff on ebay and did his black car with it. It looked very good . Dont know about durability and i did inspect the car.. it wasnt as slick as i woukd have thought, the beading if water looked average to me but it was very very shiny
Are they the same products or get what you pay?
buy both and do half of your car with each. then you can tell us.
I've used CQuartz on one of our vehicles and I can say it performs extreamly well. It looks amazing, but more importantly it has been very durable so far and the self-cleaning/water sheeting properties are amazing. Water seems to nearly bounce off the vertical pannels and on more horizontal areas, what doesn't roll or sheet off the surface leaves these tiny, tight beads which almost seem to be more like little spheres of water perched on the surface.
You mention this other product only had average water beading. If we both consider "average" to be the same properties, I'd say the product your neighbor is using probably wouldn't even stand up to even some of the better sealants sold here, let alone the reputable coatings like CQuartz and Gyeon.
Slickness in feel is not a good measure of a coating. Many of the good ones don't feel slick like a wax or sealant, but that seems to be related to their hydrophobic properties. Even Sonax Polymer Net Shield, which is a sealant which behaves like a coating when wet, isn't very slick, but the water behavior is amazing.
I’m going to be putting cquartz Uk and mr fix up against each other, I’m thinking uk will easily dominate but I’m always curious.
I did not like mr fix 9h. It was extremely difficult to buff it from the paint after applying it, very tacky, required a significant amount of pressure to remove. Couldn’t imagine doing the entire car with it. It’s possible I got a bad batch, I also think the version I got was different from the Veteran version that others have reviewed. Gloss was great, water behavior was below average, durability as far as maintaining its surface tension was poor, definitely requires a top coat of some sort.
CQUK blows it away in performance while being much easier to work with.
I washed,clayed,griots correcting cream,panel wipe and mr fix, I laid it on thick and it leveled out no problem, of course that doesn’t matter if it doesn’t last
Mr Fix 9H has big problems with authenticity or quality control. Performance varies widely between users.
The bottle I have works great nonetheless, on par with CQUK. Beading is really outstanding after a few months and some hits with degreaser.
Search for bottles with scratchable certificate, which you can verify online and has bigger writing on the package, around 10$ - this stuff should be legit.
It smells a lot like igl poly
Had another look at my neighbours mr fix 9h car..
It rained abit this week and it all looks dusty.. BUT i touched it and it really appeared to be on the surface and just a finger swipe appeared to take off the dirt, it was off and shiny and slick again..
In fact it feels slicker than it did the first time i saw it 24 hrs after when he applied it
Thinking to trying some. Could it keep Cquartz honest?
Spend $100 AUD for 50ml cquartz or buy 3 x mr fix 50ml for $20 AUD and smother it on with 4 coats
If you look on Alibaba.com you will see many different coatings being sold at very low prices. Some people buy these coatings by the liter and transfer it to smaller bottles and make a big profit. Some coatings are just relabeled and sold under several names (just like many other detailing products). Many manufacturers will work with you and bottle the coating and ship it to you for you to put a label on. You will never get a manufacturer to tell you who they sell to but a tip off is the bottles and tops they use.
Is a $10 coating as good as a $100 coating? The only way to know is to try both. The $100 coating probably has more advertising costs (and other) raising the price.
Saw my neighbour wash his car. He has mr fix on it. Was slowish to sheet but did seem to sheet water off.. very slow though.
Didnt seem to bead just sort of runs off slowly.
I thought the water was supposed to fly off it?
Depends also on the panel angle and the level of contamination - meaning both dust that settled on it, and heavier bound contaminants, that stick to it or get embedded into it, as time passes. Unless the car was freshly washed, the water behavior doesn't mean much. Even then contact angle should be primarily observed to determine hydrophobicity, as beading and sheeting depend heavily on water spray pattern and panel angles/lines.
Regarding CQuartz, it's definitely overpriced in the sense, that you can get the very same product (and I mean that literally) from the original Korean supplier (TAC) to CarPro, for almost half the price (well, 60%). That said even that product costs like $35-$40 for a 50 ml bottle, which is still multiple times the price of Mr Fix, which in turn means, that the latter just can't be of the same quality. Which doesn't mean it should not be used or that it couldn't perform well - just that at some level there must be a difference between these products.
Unfortunately I can't speak of personal experience, because even though I have a bottle of Mr Fix for more than a year here, it still couldn't get myself to try it on a car.
Shows how good these generic, cheap coatings are. It could just be contaminated but since it hasn’t been that long since application, I suppose the coating is already wearing off.
There's a YouTube channel from Texas where this guy puts many different products on one hood. The spot he used mr fix 9H on, didn't last but 3-4 months. Based on that not worth it to me. Get a tub of fk1000p and get better durability.
The new upgraded mr fix, goes on a lot thicker, does a nice job of filling and darkening the paint, used it on some not so perfect paint to see what it could do, still the longevity is what we’re all looking for, it seems the trusted brands make that a top priority, cquartz uk has been impressing me from every angle
I used the mr fix over solutions finish on trim and sometimes on wheels it is a legit coating but lacks the additives for gloss and water behavior and that’s the biggest factors for me. I also use on wheel and headlights I let some streakin just to see how hard it was to buff off. My two cents.
Hate to revive a dead-thread but I actually just purchased CQuartz UK 3.0 and I already had 2 containers of Mr FIX9h. I already had MrFix on 1/2 of my hood and just applied CQuartz UK 3.0 on the other 1/2. Will let the CQuartz cure and then take a look at the water behavior.
I have used Mr Fix in the past and it actually lasted a good 1 years and 6 months on my car, but I am a rabid cleaner so I constantly applied wax and sealants over that coating which probably extended the life of the coating. I want to compare the water behavior, but right now the biggest
short-term difference I noticed was that CQuartz does look a bit darker and deeper on my black paint.
If you had issues taking off Mr Fix, you probably did not take it off correctly. I found it much easier to use than Cquartz Products I have used in the past. The trick with Mr Fix, as per the instructions, you have to first take off with a Damp Microfiber towel, then immediately wipe dry with a dry Microfiber towel. If you do not do this? The product is very hard to remove and is very tacky as you mentioned. That is how I know you didn't do it right haha.
