Eldorado2k
- Nov 9, 2015
- 14,429
- 534
Hey guys, I’m posting this to hopefully get some tips on what I could’ve done different. Or maybe my expectations were too high? I dunno, check it out.
This is the test subject. Toyota Tacoma, not sure what year but contrary to how it looks it’s not that old. Headlights are extremely hazed.
Ok so 1st I tried out McKee’s AIO Headlight Restoring Polish w/3” Yellow LC Flat Foam Cutting Pad on speed 6. This is the result.
So obviously that wasn’t gonna cut it, so I began the sanding process using the 3M Headlight Restoring Kit.
1st up was 500 Grit. The kit says to dry sand during this step, but I decided to wet sand instead using Megs D144 as the wetting agent. I used my HFDA with the 3” sanding disc for most of the headlight, and then sanded by hand with the supplied hand applicator for the round edges of the light.
Here’s what it looked like after 500 Grit Wetsand.
Here’s after 800 Grit Wetsand.
Here’s after 1000 Grit Wetsand.
Here’s after 3000 Grit Wetsand.
And finally polished out the sanding marks using the same pad & product that I previously mentioned. This is the final result.
Another pic of the final result.
I was expecting better results than that... There’s still a bit of cloudiness in the headlight and it’s just not crystal clear like I was hoping it’d be. IMO it’s just slightly better than the AIO polish by itself...
So what do you guys think? Were my expectations to high? Are Toyota headlights known to be a PITA? Is that Yellow LC foam pad known to suck? Should I have dry sanded for 500 and 800 grit like the kit suggested? Let me know what you think.
