Was looking into purchasing the cr spotless and had a few questions hopefully someone can answer...
1) can it be used with a pressure washer( if the gpm is less then 2.5)? I have a Briggs and Stratton 2500 psi gas and a dirt devil 1600 psi electric
2) can you follow up with drying it with a master blaster or does it have to be naturally evaporated?
3) can you use it with a rinseless wash, essentially using the water from the cr spotless in the rinseless bucket?
Thanks
Thanks
