crystal mist/ souveran paste wax
BILL
Can souveran paste wax be applied over crystal mist with out one canceling out the other........
crystal mist weekly, souveran paste wax monthly:
good idea???:confused:
Crystal Mist is designed to enhance Souveran and the other Pinnacle waxes. It works equally good with most/all carnuabas. You could use it below Souveran I suppose, but have never done so prior. On weeks were I use Souveran I dont use CM, but the weeks inbetween at each washing (twice weekly) I use it to amp up the shine.
So i guess its ok to use it under souveran........i guess one just builds on top of the other, after all they are from the same family of waxs
thanks killrwheels :)
To answer your question.........Yes you can! The 2 products work nicely together.
I would remind anyone that to date I have not found a true carnuaba that did not benefit from Crystal Mist in keeping the "pop" alive. It may not be needed initially, but is clearly a benefit between waxings. And is so darn easy to use, just wipe, no setting or seperate removal.
Thanks........ordered today from autogeek and was e- mailed an hour ago its already been shipped.
thanks again..............
