CTEK Battery Chargers Now Available @ Autogeek
Nick McKees37
McKee's 37 Product Support
I'm excited to introduce the addition of CTEK Battery Chargers to Autogeek!
CTEK Power Inc is the manufacturer of what many consider the best line of battery chargers in the world. CTEK researches, designs and manufactures a unique line of high-tech battery chargers and special solutions for all types of lead-acid batteries. This includes applications for both private and professional use. CTEK battery chargers are promised to outperform and outlast competing products.
CTEK battery charges are built with quality, simplicity and performance in mind. Every component of a CTEK battery charger, from the easy-read display to the insulated battery connectors, is designed to exceed the needs of both inexperienced and experienced users. CTEK battery chargers can withstand environments and weather conditions that no other battery charger on the market can.
Since CTEK’s inception, nearly three million battery chargers have been sold in 60 countries throughout the world. CTEK also supplies battery chargers to some of the most prestigious car and motorcycle manufacturers. CTEK battery chargers have won numerous awards from some of the most reputable publications including Auto Express.
From lawn mowers to classic cars, CTEK will surely have the best battery charger for your application and needs.
:dblthumb2:
great product ---- have had one on my Vette for years. I believe they come standard on Lamborghini's also.
Dp these chargers have temperature compensation?
Most CTEK chargers are designed for all weather conditions.
Here's a quote from the UC 800 product description:
The UC 800 is prepared to charge and maintain, no matter the weather, temperature or situation. The UC 800 is very light and compact, but it is extremely robust and water and dust resistant (IP65 classification). The UC 800 is certified for use between -4°F and +122°F. In order to make things easier and more convenient, the Comfort Connect (eyelet terminals) can be permanently connected to the vehicle's battery.
Temperature compensation changes the output of the charger based on the ambient temperature.
True...
But doesn't the UC 800 CTEK allow for such ambient-temperature swings?
("The UC 800 is certified for use between -4°F and +122°F".)
Have I missed something here?
I suppose another way of asking this is:
What role does ambient temperature play in temperature compensation for a car battery charger?
-I'll say that CTEK, and other "trickle-chargers" of its ilk, have modern-day electronics that control ambient temperature
compensations, that fall within a range (that's peculiar/particular to each charger 'brand'), while a battery is being charged.
-However:
Doesn't a vehicle's charging-system provide a pre-determined/fixed voltage (by the OEM's...~13.8 to 14.4 V)
that adjusts to ambient temperature, while the vehicle is in use?
The latter would seem to be the more important of the two ambient temperature examples so given...IMO.
Anyway...Aren't most battery-charging-sessions, provided by trickle-chargers, usually done in a rather controlled-clime?
Irrespective of any of the above ramblings of mine:
-Extending the life-cycle of an automotive battery by reducing sulfation; and:
-Avoiding the results of Peukart's Law...
Was at least worth the investment of CTEK-type battery chargers for my vehicles (thus: batteries) storage/non-DD's.
I found this description to be amusing.
"CTEK Multi US 3300 12 Volt Charger
The CTEK Multi US 3300 12 Volt Charger is a versatile battery charger in a compact format that makes it convenient and easy to charge and maintain all household vehicles. The special cold mode means that you can also charge during cold winters days without problems. Perfect for car, vintage car, personal water craft, boats with one battery, boats with start & service battery, scooter, motorcycle, Quad/ATV, lawnmower, caravan, and tractor."
Like this?
[ame=http://www.youtube.com/watch?v=caQnMXJIBns]FIAT 500 ABARTH Charlie Sheen - YouTube[/video]
