Cure time for SigII?
stealth
Hey, just wondering what the cure time is for SigII. I will be applying two coats for even coverage. I have heard 30mins to let a wax cure before you reapply. Your help is appreciated.
Just do the whole car and go back to where you started and youll be fine.
None it's a wipe on wipe off wax (WOWO). letting it sit longer does not improve anything. It's doesn't make it any harder to remove either, you just don't have to wait.
WOWO is the designed method for application, you then have no appreciable wait time if you want to apply a second level.
