I'm in process of learning this stuff the hard way (the only way I know) and I have some questions for you experts.
I am confused by the relative grits and cutting abilities of different products.
Can you list in order of grit or cutting ability of these products (feel free to include anything else you may think of):
1000 - 2000 wet/dry sandpaper common rubbing compound (like Turtle Wax, for example) common polishing compound.
Grades 1-4 of polishes from Maquires, Griot's, etc.
Also, what would you recommend after wet sanding a clearcoat (non-hardened U-pol #1) to fill the sanding, and final polish?
This is a single stage clear coat over a metallic single stage acrylic enamel.
I may have to wetsand it for overspray fogging from this job to make it more uniform looking, although I would like to try a polishing method first, but I don't know whether to try the polish "systems" or rubbing compound first or what.
I'll be using a DA polisher. Thanks!
