I own a Cyclo and a rotary. I started off with a PC and I didn't like the vibration so much so I went over to the Cyclo and I like, it's a good solid machine but I agree with Dust2Glory it does lag in the correction side. I only use it on special vehicles and that is only for giving the paint the final polishing step....you know giving the paint that poping sensation with Menzerna Final Polish II...so pro's about the Cyclo:
- Very easy to use and has a great balance
- This is just my opinion but I think it covers a good surface area with dual 4inch pads
- Either Lake Country or Edge pads work great with it, easy to install and remove pads
- It's hard to bough down the machine, the motor will keep on going no matter how much pressure you apply on the machine
Con's:
- Even though it has great weight it can work against you when doing vertical panels
- As mentioend previously it takes a little getting used to tight areas...it can be done but it just takes a little manouvering
- One..or two speed...on and off
Well these are just a few things that come to mind, as Killr said it's a great machine works great but for some serious corrections I'll cotinue to use my rotary.
Hope this helps.
