The MSDS on Meguiars D107 has a publish date of 10/31/2017 so it is a very recent product. In concentrate, the pH is between 12-13 which seems pretty good for a degreaser. If you plan on using it for interiors, I would suggest diluting it at least 20:1. That will knock the pH down to 11.178.
Suggested Dilution Ratios (Waterroduct):
Heavy Duty Strength: 4:1
Medium Duty Strength: 10:1
General Cleaning (Cold Water Extractors): 20:1
General Cleaning (Hot Water Extractors) 64:1
PH Rating: 12-13
Machine Cleaning Tip: For stronger cleaning and long-term extractor machine performance, it is best to apply Citrus Power Cleaner Plus directly to carpet and upholstery. Use the machine for rinsing and extraction only. By running only water through the machine, the pump will last longer.
Sorry, I disagree with this advice. 20:1 would render this product all but useless except for the lightest of cleaning needs except if used in an extractor solution, as designated by Meg's own directions on the label.
It definitely has the properties of a degreaser and works quite well in that task, as evidenced by the years of built up junk on the engine I did.
I have it diluted 10:1 for lighter jobs and at 5:1 for tougher stuff like engines and tires. FWIW, it works very very well as a tire cleaner also. I suppose for very light interior needs you could go to 15:1 or so.
Even though you evidently felt itGave it a chance to stretch
its legs again this weekend...
Cleaned with D107 @ 5:1
and
a little Sprayway citrus
Crazy clean foam...
