DogRescuer
- Apr 6, 2013
- 1,801
When I finish a section ( lets say half a door) should I wipe that half clean or finish the panel before wiping clean?? Thanks Steve
Finish the whole car. It's easier to see where you've done, it's more efficient, and it's believed that you get better protection. Nathan
This is my method for AIOs' application/removal:
- Work on a single panel at a time.
-"Work-in-very-well"...the few drops of the AIO,
that I've put on either an applicator/polishing-pad...
until the film is nearly gone.
- Allow this AIO-film to haze for just a moment;
and, then buff off residue with a MF-towel.
Eazy-Peazy...:xyxthumbs:
I have used several gallons of this stuff over the last six years. When I use a DA like a Cyclo it does not seem to work it enough to really get a nice haze. So I would wipe after each section so it would not dry hard. But as I moved to using a flex and sometimes a rotory the results are much better. The product seemed to break down better which I know doesn't make sense seeing as it's not diminishing, but the paint came out better and the product removed easier. Now I do an entire car before wiping. Also I like to top it with a little Meg's express pray wax for some extra POP! Hope this helps.
www.JaxDetails.com
www.facebook.com/DentsAndDetails
I may be slow, but I do poor work.
