Mike@DedicatedPerfection
- Feb 26, 2011
- 12,365
I have been doing a bit of wet sanding as of late with a finishing pneumatic DA. The one I am using is a Mirka with 3mm orbit. I know it is labeled as a finishing sander as a last step to finish with. Although I recall seeing somewhere that the 3M Trizact foam finishing discs should use a larger stroke DA to help keep the disc from clogging up with removed clear coat however I can not seem to find the information on what sized throw DA should be used. There is nothing on the box.
For sanding operations with 1500, 3000, 5000 paper I have been using 8mm and smaller. Curious as to how much more throw could be used in this scenario. Anyone try using a large stroke DA for sanding operations?
