da pads for a rotary ok?
purgeofdarkness
tried searching for "da with rotary" and came up with the while forum. I was wondering if the da pads can be used just as effectivly with a rotary. I dont see why not but I dont know if theres a science behind it.
They work just fine on a rotary. I use all my pads on the rotary from time to time with no problems, in fact a rotary is less likely to tear up pads than is a DA.
I highly suggest the HT pads on a rotary. I've been using the same pad, over and over and over now, still hasn't shown any sign of it destructing. And i go for it over my ccs and flats. :)
IMO, you can't beat the LC Kompressure pads with a rotary. So smooth especially around uneven surfaces.
Hi guys what are the best pads for cutting scratches out, not just swirl marks etc.I mean deeper scratches.I have used ccs pads,and are know useing hex pads with a shinex wich do not seem to cut to well.
Thanks Kevin
