It is certainly possible to use an air polisher to polish paint, but it is important to note that typically with an air DA it is much easier to stop the pad from spinning than it is with an electric polisher.
You won't be able to put as much down-force on the pad especially if what you're using is a full size 6" or 6.5" foam pad. My 6" air DA usually only sees sanding duty as a result.
That said, the videos I have seen of the 3" "mini DA" air polishers look very slick, and I'm dying to pick one up to play with.
