DA Polisher Question
gmcsierra
Can I Use A Meguiar's Soft Buff 2.0 Foam Pad (Black Version) To Buff The Wax To A Shine After It Dries? Input Is Greatly Appreciated.
You could apply the wax with the foam pad. You will typically want to remove the wax with a microfiber towel or microfiber bonnet that fits over the pad.
Sent from my LG-LS720 using AG Online
Ok, so can I just use the microfibre towel over the pad, or do I need the bonnet thing?
No, use the microfiber towel by hand, or get a special bonnet. Use the DA to apply the product, when if flashes or hazes over and is time to remove put the DA down and buff off with you MF towel.
i wouldn't remove wax/sealant by machine, use a soft quality mf towel and do it by hand. if you apply it on very thin, it should be a breeze to move...
