ScubaCougr
- Oct 19, 2010
- 558
New to using a DA, I found a car I could practice on, and in the owners words "not hurt anything"...his 1973 Nova.
Originally set up to drag race, The Beast is designed for go, not for show. He's owned it for a dozen years, drives it to work occasionally when he wants to scare small children, and otherwise it sits outside.
So last Saturday, this is what we started with:
Washed, clayed with DP Universal Clay that revealed a decade of oxidation:
Since the paint was a fast garage re-spray not original, I used a Griots and 5.5" LC CCS Orange pad with XMT 2 until I ran out, then switched to Megs Fine Cut #2 to remove oxidation.
The Megs #2 was a pain...dried almost instantly despite temps in the mid 60s and being garaged. Single pass, then wipe like crazy with a MF before it dried like cement. But progress was being made. I've always thought it was a black car...
A couple passes with XMT 360 and a CCS white pad removed most swirls. It's now a 10 foot car, not a 20 footer, and the neighbor says I can practice on it anytime...
Lessons:
Thanks for reading, advice for next time welcome...
:xyxthumbs:
Lessons:
- The Griots has plenty of power. Worked OK on wheel arches and other curved surfaces without full pad-contact. I can move to more 6.5" pads to speed production.
- I need a bigger selection of compounds. I was aiming for least aggressive product, but XMT 2 was a bit too timid for the beast.
- You can never have too many pads or too much compound. I could easily have used 3-4 pads each to avoid constant washing, and used more than a bottle of XMT 2 and 360. But now that I know a bit about what works, BOGO Friday is coming.
:xyxthumbs:
