Elliot@Autogeek
- Apr 24, 2017
- 362
Dakota Odor Control Products feature the Dakota Odor Bomb and Dakota Non-Smoke for car odor removal.
Known for their great odor relief, we are now carrying Dakota cleaning products!
Dakota Fab Foam Carpet & Upholstery Cleaner & Odor Eliminator
Don’t mask bad odors and stains – eliminate them!
Dakota Fab Foam Carpet & Upholstery Cleaner & Odor Eliminator is an advanced formula of active enzymes that work to fully eliminate organic matter in stains and foul odors. The thick foaming action works to penetrate deep into the carpet and upholstery’s fibers for complete removal. Perfect for use on most interior carpet and upholstery in automotive and household settings, Dakota Fab Foam Carpet & Upholstery Cleaner & Odor Eliminator provides the perfect level of clean for any stain or odor!
Dakota Fab Foam Carpet & Upholstery Cleaner & Odor Eliminator features:
• Advanced cleaning with foaming action
• Active enzymes that eliminate organic matter and foul odors
• Pleasant fresh fragrance
• Inverted valve for easy, comfortable application
Our Price: $7.99
Sale price: $6.99
Dakota Shine Interior Vinyl & Plastic Coating
Brighten the look of any vinyl or plastic!
Dakota Shine Interior Vinyl & Plastic Coating is a grease-free, streak-free formula that provides an even layer of protection on your plastic and vinyl automotive surfaces. Dakota Shine Interior Vinyl & Plastic coating leaves a matte, satin finish without being sticky or tacky. Perfect for those hard to reach areas, Dakota Shine Interior Vinyl & Plastic Coating lets you spray and walk away with a freshly detailed interior!
Dakota Shine Interior Vinyl & Plastic Coating features:
• Matte finish
• Fresh watermelon scent
• Greaseless and streakless formula
• Excellent for hard to reach areas
Our Price: $6.99
Sale price: $5.99
Dakota Shine PLUS Interior Vinyl & Plastic Coating
For a GLOSS coating on your interior plastic and vinyl!
Dakota Shine PLUS Interior Vinyl & Plastic Coating provides a gloss shine on your plastic and vinyl surfaces, without that greasy feeling or streaking! With no wiping required, Dakota Shine PLUS Interior Vinyl & Plastic Coating allows you to simply spray and walk away and is excellent for treating those hard to reach areas. Keep your interior plastic and vinyl surface GLOSSY with Dakota Shine PLUS Interior Vinyl & Plastic Coating!
Dakota Shine PLUS Interior Vinyl & Plastic Coating features:
• Watermelon scent
• Works instantly
• No wiping required
Our Price: $6.99
Sale price: $5.99
Dakota Glass Cleaner
Premium, foaming glass cleaner!
Dakota Glass Cleaner is a foaming glass cleaner designed to lift away even the toughest soils on all glass surfaces. This non-ammoniated formula is safe for use on tinted windows and will not streak, smear, or rainbow and does not cause build-up. Clear glass is a must when it comes to vehicles and Dakota Glass Cleaner will clean and restore your crystal-clear glass finish.
Dakota Glass Cleaner features:
• Foam on, wipe dry formula
• Non-ammoniated
• Cleans and restores
• Shines
Our Price: $4.99
Sale price: $4.50
Dakota Tire Gloss
A foaming, high-gloss silicone dressing!
Dakota Tire Gloss is a versatile, water-based formula that provide a “wet” look on tires, exterior moldings, engines, and vinyl trim. In addition to a deepened color and water-repelling surface, Dakota Tire Gloss also creates a layer of protection on treated surfaces that prevents discoloration, drying, and cracking – no brown tires here! For a long-lasting tire shine, Dakota Tire Gloss is just what you need!
Dakota Tire Gloss features:
• Use on tires, exterior molding, engines, vinyl trim
• Water-based aerosol foam
• Gives a “wet-look” shine
• Repels water & prevents discoloration, drying, and cracking
• Works great on interiors
Dakota Tire Gloss
Our Price: $9.99
Sale price: $8.99
Dakota Tire Shine Foam
Tire & vinyl shine!
Dakota Tire Shine Foam is a non-chlorinated, self-clinging foam that shines, renews, and protects tires and vinyl surfaces. Used to prevent discoloration, oxidation, and ozone deterioration, Dakota Tire Shine Foam provides a long lasting protective shine that repels dirt, salt and grime. Dakota Tire Shine Foam contains no harsh solvents and is safe for use on vinyl and rubber vehicle surfaces.
Dakota Tire Shine Foam features:
• Non-chlorinated
• Renews & protects
• Prevents oxidation
• No harsh solvents
Our Price: $6.99
Sale price: $5.99
