Shinystang
- Feb 14, 2007
- 36
Purchased a black '79 T/A with a 20 yr old repaint. Flat surfaces were very rough and heavily oxidized. Polishing with Megs 105 clogged the w4000 with a black gum. Results were mediocre at best.
After seeing Mike's damp sanding article, decided to try 1500 & 3000 on the PC.
I'm not an expert and I do this for fun only. I was pretty impressed with the results and the speed. Please pardon the rest of the car. I have only done the hood....the rest still looks rough and is covered in compound.
1. Wash & IP wipedown
2. Water only spritz on surface and 1500, then 3000 with 4 section passes per area
per sanding disk, PC speed @ 5.
3. Megs 105 on w4000 @ 1500 rpm
4. Megs 205 on Megs yellow 2.0 foam pad @ 900 rpm
5. Menzerna po85 by Flex 3401 on gray foam, speed 5
6. Natty's Blue on sponge applicator
Oxidation AFTER rotary attempt to remove
Left front hood after damp sanding
Left front hood after Megs 105 on w4000
Left front hood after Natty's Blue
