Define the terms Detailing & Paint correction
215Detailing
At my nine to five a coworker says I hear that you Detail cars, I state - yes I do Detailing and Light Paint correction. Now questions are flying, what is Detailing - I state that what I call Detailing can be a series (Levels) of Cleaning from basic to Thorough deep cleansing and that Paint Correction = corrects Defects in Paint such as marring, scratches, oxidation bird drop etching and so forth, They I hear from one coworker that the people that does their car uses a buffer to detail all the time, I state that only time a buffer/polisher is used for my detailing is for wax application and any other Buffing is for me is consider PAINTCORRECTION..
Hope Mike Phillips chimes in all others comments are more then welcome, I feel as some people don';t unstand the Two or some folks like to try to get a discount and combined the two...am I wrong ? Feed back please Thanks to all in advance
Great questions and you'll probably get all kinds of answers...
Here's some related articles I've written and I define the different steps a person would do in my first how-to book,
  • The Major Correction Step
  • The Polishing or Minor Correction Step
  • The Sealing Step
  • One-Step Production Detailing
Most detailers are doing production work, that is using a one-step cleaner/wax or AIO, (same thing). There's a great thread about it here...
I'm Going Back To Basics with an AIO
My article below actually talks specifically about this topic you bring up...
A few tips on starting a part-time detailing business
Match your services to your customer
First... match your services to your client or market
Over the years here's the normal trend I see on detailing discussion forums...
  • "Car Guy" or "Car Girl" joins car detailing forum reads, asks questions, increases their knowledge.
  • Purchases products, often times moves up to machine polishing because clear coats are too hard and too time consuming to work on by hand.
  • Sees first-hand, phenomenal results from their new found knowledge, skills and abilities.
  • Starts a part-time detailing business.
  • Makes the mistake of offering "Show Car Detailing" to a customer base that knowingly, or unknowingly wants and will only pay for "Production Detailing".
The above two terms for the purpose of this article are generally described as...
Show Car Detailing = Multiple Step Process
Production Detailing = One Step Process
The point is, for most people just starting out the majority of your customers are going to be people with daily drivers and this demographic group are primarily interested in having a shiny car, black tires, clear windows and a vacuumed interior. They won't appreciate a 100% swirl-free finish and generally won't want to pay for it and also won't know how to maintain a swirl free finish after you with all your hard work create these types of results.
This is further explained in this article,
The difference between a swirl and squirrel
Someone just starting a part-time detailing business usually has very noble goals and strives to create show car results for every car they detail and I understand your passion as it is explained here,
The Mindset of a Professional Detailer
That said, you need to match your services to your target market and by this I mean you don't want to offer a multiple step process to the average person with a daily driver that includes,
  1. Car Washing
  2. Claying the paint
  3. Paint Correction - Removing swirls, scratches and water spots
  4. Polishing - Maximizing gloss and clarity by refining the results from the correction step
  5. Sealing or protecting the paint with a car wax or paint sealant
And here's why... the above is a multiple-step approach, it will take you more time than doing a one-step and in most cases you won't be able to charge your demographic market enough money to make enough profit to make it worth your time AND be enjoyable. Working for free is a fast way to take all the fun out of a hobby that's turning into a business.
Instead when first starting out you should be doing a one-step processes or one-step detail jobs.
  1. Wash
  2. Clay
  3. One-Step Cleaner/Wax by hand or machine
This is what's called a One-Step Process, it's actually 3 steps but washing and claying are accepted normal procedures in this day and age for detailing cars whether you're doing Show Car Detailing or Production Detailing.
If you want to do show car work, that is a multiple step processes, then I would recommend to first evaluate your customer and make sure you're matching your services at a profitable price point to customers that actually want show care results.
Don't do show car detailing for someone that is going to run the car through a car wash as a normal maintenance procedure. It won't be good for you and it won't be good for your potential customer. You should target show car work to people that will appreciate your hard work and that will appreciate the results as well as be knowledgeable enough to understand that clear coat paints are scratch-sensitive and require proper care to stay swirl free.
Since the majority of people that will pay to have their car washed and waxed, (so they don't have to do it themselves), will fall into people that own Daily Drivers, and this larger target market will fall into the category of Production Detailing or in other words, doing one-step procedures to the paint.
The general goal of this type of work isn't to remove ALL the swirls, but to simply make the paint shiny again. Most people don't know what swirls are, they see paint that is either shiny or it's not shiny.
KISS - Keep it Simple Simon
Here's the good news... it's easy to make paint shiny! Show Car Detailing has been historically time and labor intensive with a measured amount of risk. Production Detailing or doing One-Steps is a lot faster, requires a lot less work and there's very little to zero risk. You just follow the basics,
1. Wash and dry car to remove loose surface dirt.
2. Use detailing clay to remove above surface bonded contaminants and restore smoothness to the paint. This is key because gloss comes from smoothness and restored gloss is a powerful visible before-and-after result that your customer will notice.
3. Use a quality one-step cleaner/wax to clean, polish and protect the paint. A quality cleaner/wax will remove surface oxidation, staining and minor surface imperfections. S cleaner/waxes will even remove and/or reduce minor or shallow swirls and scratches. A quality cleaner/wax or cleaner/paint sealant will restore clarity to clear coats and increase shine. Again, these are dramatic before-and-after visible differences that your customer will notice and appreciate.
And just to add, claying the paint with detailing clay also enables your choice of wax or paint sealant to bond better to the paint thus last longer and thus protect longer. These are benefits your customer wants but may not understand very well the reasons why claying helps wax to last longer so this is where you have the opportunity to educate them and set yourself apart from the average detailer with your knowledge.
(Use this to get referrals)
4. Apply some tire dressing to restore a deep, dark black appearance to the tires, clean the windows, vacuum and clean the interior and make sure it smells clean with a fresh scent and that's your basic service package and for the majority of car owners that's what they want, knowingly or unknowingly.​
When first starting out, try to keep things simple, for example offer 4 plans each with it's own price point.
  1. Simple Car Wash - Wash and dry car. (Up-sell dressing tires, cleaning inside of windows)
  2. Interior Detail
  3. Exterior Detail
  4. Interior and Exterior Package
Create a consistent monthly income
Also offer a Monthly Maintenance Program with monthly billing. For an agreed price, once a week or twice a month or even once a month provide one of your services to maintain your customer's car so it always looks great. Once you do the initial detail maintaining their car into the future will be fast and easy and by setting them up on a regular schedule with monthly billing you will insure a consistent income at the beginning of each month for your business. Most of the detailers I know that have been successful offer monthly maintenance programs and make this the focus of their business. Keep it simple so you keep if fast and always be prepared to pick up a new customer at the location you do the work.
  • Wash once a week
  • Wash and wax every other week
For both of the above you will also include vacuuming and cleaning the windows but keep in mind, after the initial detail where you do the brunt of the work, these follow-up maintenance sessions will be very fast and easy. What your customer will appreciate is that there car is meticulously clean each time the see it and all the time they are in it, and a lot of professionals in any industry appreciate this kind of luxury and are willing to pay to have someone else maintain their vehicle.
Show Car Detailing
Go for the show car work if that's what you're interested in but target the Corvette owner, BMW, Lexus, Cadillac or any owner of what you think of as "Special Interest" cars. Keep in mind that what you think is "Special Interest" may not be the same as your customer, so be sensitive to other's preferences.
For example, I'm not trying to pick on PT Cruiser owners but just as an example, some people would view these cars as just a normal car while the owner may view their PT Cruiser as a "Special Interest Car" and marketing a multi-step process to an owner that will appreciate and take care of your hard work can be a profitable win/win deal.
Of course, show car detailing requires more skill and experience than most people just starting out have so don't run before you can walk. If you're just starting out get experience doing production detailing on daily drivers and continue gaining knowledge by reading discussion forums like AutogeekOnline.net and try to attend as many detailing classes as you can, always be open to learning about new products and procedures, this is something I practice myself.
Also, look at the websites of some of our regular pro detailers, (that have websites listing their services), to get an idea of what they charge for their packages. Don't try to re-invent the wheel but also don't copy other people's work word for word.
I just wrote an new article on how to put up a website for about $20.00 a year, here you go...
How to put up a website for about $20.00 a year
Be sure to read these articles before purchasing a domain name...
Check out this article too...
The story of 3 H's - Horrendous, Horror Story and Hack Detailers...
:xyxthumbs:
What did I see you say before Mike? Polishing paint is polishing paint and detailing is getting the wax out of the cracks. Or something like that....ha
Thanks Mike and other forum members all help is much appreciated
I recently had a discussion on another forum about polishing where there was a disagreement on what a polish is.... bit unrelated to the topic on hand but the reason why I mention this is because the other party, apparently a detailer, thought I knew nothing about detailing and was using terms that he would use on his customers. Later during the discussion when he figured out I knew a bit more than nothing, we had a mutual understanding of each other.
I guess my point is and as Mike said, most ppl dont know the difference between a swirl and squirrel. IMO, if they want to call a wash and wax a detail... so be it. But it would be only fair to let them know exactly what you are doing.
Thanks for you feedback, I to have several services that include waxing so yes I consider a wash & wax a form of a DETAIL, but not part of PAINT CORRECTION same ballpark two different playing fields to me paint correction requires more than basic knowledge & skill and you have a large tool use requirement (Polisher/Buffer) used to reduce or remove defects from paint thus equaling correcting. so you have DETAILING the cleaning part/ and then you have PAINT CORRECTION the skilled labor & knowledge to correct paint issues.
Detailing Terminology Obsessive Car Detailing - Professional Full Service Mobile Car Detailing in Los Angeles and Orange County CA
This company (Detailing | Glenside Auto Spa) is not too far from me,now He charges $85.00 for a 3 step correction listed as a FULL EXTERIOR DETAIL:G-SPA CAR EXFOLIATE (Full Exterior Detail) : $84.99
Includes power wash pre-treatment; hand wash, remove all tar, bug, & road grime, 3 Step process-compound, polish, and glaze exterior with high speed buffer, hand wax, clean and dress tires and rims; windows cleaned; Your exterior will have a showroom shine! (+$10 SUV/ + $20 Oversized) i charge $100. without CORRECTION, and this is why I believe so many customers are confused or want more for the PRICE.
I have a couple of places by me that do the exact same thing which use to confuse me when I started thinking about setting my prices...
yes it becomes confusing also on the service end because most of these place do a 3 step correction in less than eight (8) hours and there rates are below what I beieve is the norm for a shop with overhead of a lease.
We are very lucky in the UK as detailing means paint correction, whilst valeting means general wash etc (obviously in the US you have another meaning for it)
Detailing means in depth cleaning, valeting means having someone else park your car.
I like that, wish more folks here would separate the two as well as paint correction would bring in more money if you are skilled and even at various levels from BASIC DETAILING (cleaning)
