98LowRanger
- May 2, 2014
- 302
This year I added a CR Spotless deionizer to help reduce a water spots issue I was having last year. I feel like it greatly helped, but wasn't 100%. The gauge reads that I need to add fresh resin to the deionizer even though I have only used it on about 25 washes (I don't even use it for cleaning wheels/tires/wheel wells). So I was considering adding a separate water filter or water softener system BEFORE the deionizer. I figured my well water was pretty bad, but I have to do something to help conserve the resin in the deionizer since it is so expensive. Do you guys feel like this is overkill or is there something else I can do? I was considering one of the filter systems from Autogeek btw.
