Detailed 04 Volvo Xc70
Bubbabuff
I was pleased how this one turned out, the paint definetly wasn't taken care of.
--Washed with C.G CW&G via foam cannon (first wash)
--Washed down with C.G CW&G via AG pro wash pail with grit gaurd (sheep skin mit)
--Amazing roll off to wheels and tires
--Separate pail for wheel wash/tire scrub
--Clayed with Wolfgangs poly clay/Optimum clay lube
--wet sanded scuffs with 2000 grit--then polished out with Menzerna SIP with orange pad. Amazing results
--Menzerna SIP with White PAD via PC 7424
--Alcohol wipe down
--Menzerna NANO with Grey PAD via PC 7424
--Alcohol wipe down
--Wofgangs DGPS, let cure for 12hrs
--Topped with Pinnacle Souveran paste wax
--sealed wheels with Poor boys wheel sealant
--Tires with Extreme shine
Nice turn around. What did you wet sand and did you have to use a lighter grit after the 2000 or was sip enough to take out the sanding marks?
Starting from the left, its picture #4, you can see the wet sand markings. SIP with orange pad never have an issue when polishing wet sand marks.
