ehuth1
- Dec 9, 2006
- 1,140
- Degrease Problem areas with *PB Bug Squash (tar, bugs, mud etc...) and followed with quick Rinse
- Clean wheels, tires and wells with "The Brown Stuff" Spray on let sit for 5-10 seconds and rinse.
- FOAM GUN - 2oz of DG901 and 1oz of Wash-N-Wax the rest water. 65% mix rate.
- Let this sit for 5 Minutes and now I pop out the foam attachment and pop in the sprayer nozzle. This was done with the Karcher 1400psi unit.
- Spray off foam. Start at the top and make my way down to the bottom.
- MF Towel dry using DP 4-n-1 QD. This breaks the water and releases it to help my towel from soaking to much up too quick.
- Next we drag the vac out and start in the rear and come to the front hitting all the cracks and crevices. Then I apply dressing to all door jambs and rubber seals.
- Grabbed a old MF towel and used some MEGS ID to clean the scuffs and cup holders.
- I always do the tires (UV2) next along with the wells (AA Tire Foam), running boards (303), and bumper trim (303), then I follow that up with the cleaning of the wheels and chrome bumpers if any with Clearkote QS.
- While I'm waiting for the tire shine to settle in I go inside and wash my hands and get my waffle weaves and Stoners IG and hit all the windows inside and out.
- It's just about time for XMT 360 via orange CCS. This paint was in decent shape with hardly any rough spots. This to works good outside so you can see your results, so off I went. Next step was to finish with Pinnacle LS then cover that with Pinnacle Spray Souveran. This paint was really looking good !!
- Now it's time to final inspect and move to the next of 3.
DURING POLISHING AND TRIM APPLICATIONS
AFTERS
