DFB
- Aug 12, 2019
- 4,594
- 2,366
##NOTE## - I've written this piece for a couple of other forums. However, I debated if I should put post this here too, mainly because it flaunts the product rules for this forum more than usual. So, I totally understand if this post is deleted. I did put a lot of work into it, so felt like I wanted to share it here too.
DFB’s Detailing Awards 2024
Well, if a certain Youtuber can give out yearly detailing awards, then why can’t I? The difference here though is I don’t have a conflict of interest, sell my own products, or get sent a bag of money to say nice things about average products and brands. So, the following is my inaugural detailing awards……………………….with guaranteed no deleting of videos or comments!
Best Tyre Cleaner (Dedicated) –
In a tyre cleaner, I want something that lathers up under agitation and delivers a nice bare rubber surface. I'm not sure why, but I’ve found products that lather nicely give the impression that they are cleaning more effectively.
1st - Shine Supply Wise Guy
I like how strong this product is and the value it provides. Lathers well and cleans exceptionally. Can also be used as a wheel cleaner if needed.
2nd – Carpro Retyre
I consider this product to be a sledgehammer, its foaming trigger helps deliver that lather I’m looking for to strip tyres bare. It’s a bit strong for regular use, hence Wise Guy winning overall as its more versatile.
3rd - Adams Rubber & Tire Cleaner
This is one of the best on the market but is priced out of contention in Australia, made worse by not being dilutable. But it cleans so well, which redeems the price shortcomings.
Best Wheel Cleaner -
This is a hard one to arrive at winner because there are three main types of wheel cleaner; alkaline, iron removing, acidic. No one is using acid anymore, so it comes down to if you need that iron-remover aspect.
1st - P&S Brake Buster
I like this because its versatile. Use undiluted for heavy duty wheel cleaning, or dilute for regular use. Used undiluted, it’s a great maintenance tyre cleaner. It also foams like a champ, which helps keep the product on the surface for longer. It’s also slick and lathers up nicely under agitation.
2nd - NV Purge
Now, if you are dealing with cars that produce a lot of brake dust, then this could be in 1st position for you. Purge is the best iron-remover wheel cleaner on the market and is relatively affordable compared to its competitors. Unlike a lot of similar products, Purge’s sulfur stench is well masked, and although not pleasant, its tolerable.
3rd - Armour Detail Supply Wheel Cleaner
This product works in a similar way to Purge, just without the value for money equation. It’s also had the stench well masked, even more so than Purge.
Best Tyre Dressing –
In this category, I’m looking for a water-based dressing that won’t sling, doesn’t need a jackhammer to remove, strikes that balance between matte to satin sheen, and is easy to apply.
1st - Obsessed Garage Tire Dressing
This is the dressing I’m using the most, it just nails the look I’m going for. It balances the higher price with excellent coverage from a small amount of product. It smells lovely too.
2nd - Armour Detail Supply Tire+
This has that little bit extra gloss compared to OG Tire Dressing, but is controllable to taste. Again, super easy to apply with great coverage and a delicious banana scent.
3rd - NV Onyx
This has been on the market for a while now, but it still ticks all of the boxes. It’s also very well priced and the caramel scent is to die for. I love Onyx when its been applied thickly, then levelled down to uniform satin sheen.
Best Bug Remover –
To be honest, most bug removers are the same thing. However, these are the three I find work best.
1st – Carpro Bug Out
This is the product I keep coming back to for its balance of price and performance. Although its more expensive in 4-litre size, its actually cheaper than the P&S product in smaller sizes.
2nd - P&S Buff Off
I’ve found this product to be just as effective as the other two here but offered at a more cost-effective price point in the larger gallon size.
3rd - Koch Chemie Insect & Dirt Remover
Another great performer, offered with the best bottle and sprayer here, the Carpro/P&S equivalent sprayers and junk.
Best Tar & Adhesive Remover –
A tar remover should make this tedious task a breeze, melting away tar without needing excessive agitation, if at all.
1st - Carpro TarX
Not the strongest, but arguably the safer of the products on this podium. It is however extremely effective, often not requiring agitation when used on a well protected vehicle or if dealt with promptly.
2nd - Koch Chemie Eulex
Ok, so you need to be careful with this stuff, its certainly a much stronger solvent. However, for stubborn tar and adhesive removal, it can make a tough job relatively easy. Just make sure to use it in a ventilated space and rinse treated areas promptly.
3rd - Stoner Tarminator
Another sledgehammer, but if you are reaching for a tar remover, generally other cleaning chemicals haven’t done their job, which warrants that extra muscle. Again, be careful with this product, its extremely potent. I also use this for occasional tyre deep cleaning, no idea why it works like this, but it does to perfection.
Best Iron Remover –
I once thought iron removers were all the same thing, however some work much better than others. All of them stink to some degree, so I’ve chosen proven performers that are the least offensive on the nose. Also, avoid the soaps infused with iron remover, they are too diluted and just aren’t effective enough.
1st - NV Purify
NV sell this as a combined iron remover and clay lube, but I only use it for iron removal. Like Purge, this product is one of the more palatable smelling of its type, but still extremely capable of dissolving iron contamination. Its also the best value here in Australia.
2nd - Carpro IronX
One of, if not THE, first iron removers on the market, and still a segment leader. There are cherry and lemon scented versions, but we only get the lemon. Even still, IronX stinks. But…………….its one of the most effective on the market.
3rd - Gyeon Q2M Iron / Redefined
The original was non-scented, meaning it was absolutely putrid, but arguably one of the most effective. The new Redefined version is supposed to be virtually odorless.
Best Clay Lubricant –
I think most people overcomplicate clay lube, in reality soapy water will do the job at a fraction of the price. But where is the fun in that?
1st - Carpro Clay Lube
Very similar to the Gyeon version in being dilutable, but is also said to contains no gloss enhancers or protective polymers. It’s also more affordable and available in a larger size. This product was recently renamed, from Immolube to Clay Lube, the Immolube name was repurposed for their PPF slip solution.
2nd - Gyeon Clay Lube
I never saw the need for a dedicated clay lube……………..until I used this product. Previously, I was using a Megs quick detailer, but this stuff is noticeably slicker, and smells lovely too. Dilutable to suit.
3rd - McKee’s N-914
To be honest, any rinse-less wash would work here, but being that N-914 is surfactant based, its not going to leave much behind after its use. Highly affordable too.
Prep Spray (IPA) –
With a prep spray, I’m looking for effective removal of polishing oils, is safe for every surface and evaporates in a controlled way. Compared to an IPA/water mix, these products offer lubricating qualities to reduce the risk of marring prior to coating, are less likely to soften clearcoat, and don’t flash too quickly, meaning they are more effective.
1st - Carpro Eraser
I didn’t even have to think about what I’d put in 1st position here, it was always going to be Eraser. It ticks all of the boxes; lubrication, controlled evaporation, effective streak free results…………..and the most delightful scent in the detailing industry.
2nd - Gyeon Prep
To be honest, toss a coin between Prep and Eraser as they are virtually the same thing, they even smell the same. Prep went in second due to the higher cost.
3rd - Rupes Reveal
There actually two versions of this, Lite or Strong. Lite is similar to Eraser, Strong is closer to the old Gtechniq Panel Wipe and best applied to the towel and not directly to the paint, ideal for a final wipe prior to coating. Both are sleeper products.
To be continued................................
2nd – Carpro Retyre
2nd - NV Purge
3rd - NV Onyx
Best Bug Remover –
2nd - P&S Buff Off
1st - Carpro TarX
Best Iron Remover –
1st - NV Purify
2nd - Carpro IronX
3rd - McKee’s N-914
Prep Spray (IPA) –
1st - Carpro Eraser
2nd - Gyeon Prep
3rd - Rupes Reveal
