DG 601 and 105
screammachine
What's the best way to apply 601 and 105? Should I apply 601 first then follow up with 105, apply 601 then 105 mixed with 601 or just skip and a step and go directly with the 601 mixed with 105? It's my first time using any DG product so I'm not too familiar with the correct steps. Thanks for the help!
#3.
1 part 601 4 parts 105.
Don't mix more than you'll need.
#3.
...and if you do you'll need to use it up within 12 hrs, so if you happen to make more, maybe hit the windows and wheels with the extra or the front of the car, whatever you want, just use the extra.
Mix it! It is so much easier. I mix 2oz at a time. Are you applying by hand or machine?
Roger, the 12 hour thing is a myth.........I have some on the shelf that's been there for over 12 months.....it still works.
