BradsDetailing
- Sep 23, 2012
- 826
Ok so I bought a pressure washer and a foam lance recently and I've thinking of the best way to get the job done. I tried the first time by using DG 901/902 in the foam lance and then use a micro-chenille mitt to rub it down and then rinse it off with a 20 degree tip and dry with a guzzler. That worked well but I decided to try something different today.
What I did was I put 1-2 oz of DG 901/902 in the foam lance with warm-hot water. Then I filled up a 5 gallon bucket with a couple gallons and some onr.
Here are some before shots of the car
Bird Poo
Sprayed the car down
Then this is after using the onr with a micro-chenille mitt and rubbing everything down. Also it was the two bucket method. 1 with onr mix and the other water.
Then I rinsed everything down with the pressure washer and a 20 degree nozzle
And after drying
The onr with the mitt takes a lot of soap off and makes it a lot easier to dry and it was super slick. I have never been able to glide the mitt over the paint that easily before. Super slick. There was no wax or sealant applied. The last thing I applied was Mothers spray wax over a month ago.
Thanks for looking.
Bird Poo
And after drying
Thanks for looking.
