K
Kappy
Guest
Sorry for the long post, but you guys do like all the details.
Time to make the leap. I decided today would be the day I'd do a test spot, at least so I could make sure I had the correct products, and as the subject line says, I didn't get the results I had hoped for.
2012 black Nissan Murano, using a GG DA with 5" backing plate and 51/2" LC flat pads.
After doing a Garry Dean wash with ONR and claying the car, I started with M205 on a white pad first, just to see if I'd get any results.
Trying to remember everything I'd read and seen:
Covered the windshield with a towel
Marked the back of the 5" plate so I could make sure it was rotating
Marked an area on the hood a little less than 24" x 16"
Primed the white pad with M205 as shown by Mike
Added 3 small drops to the primed pad
Put the cord over my shoulder and was ready to go
Using a speed of 3, I did a few passes to spread the polish
Stopped and set the speed for 5
Did 6 section passes, 3 horizontal and 3 vertical
A few times I noticed that the pad wasn't rotating so I tried to keep the DA straighter. The hood is not really flat so I had to follow the contour or I'd start tilting a little bit to one side. I never felt like I was pressing that hard when the pad stop rotating, and sometimes didn't feel like I was pressing hard enough.
My first problem was trying to wipe off the polish. I read posts about this, but couldn't remember all of the suggestions that were made. I had some ONR clay lube handy, which I sprayed on the car, but that didn't help. I was starting to worry that I was rubbing so hard with the towel that I was going to add scratches to the paint.
I added 3 more drops of polish to the pad and did another 6 section passes. Again, it was hard to get the polish off, and once I did, the paint didn't look much better to me.
I decided to try M205 on an orange pad, instead of jumping right to M105. As I was priming the orange pad, I realized that I probably hadn't used enough polish when priming the white pad, even though I thought I used as much as I had seen Mike put on the pads in his videos. I guess it was hard for me to see the white polish on the white pad, but much easier to determine how much polish was required to prime the orange pad.
Instead of moving to a new spot, I went over the original test spot to see if I could improve it. After 6 section passes, twice, if there was any improvement it was very subtle.
On the other hand, I've had an odd drip mark on the side of my car, where some pin striping had been removed by the dealer. A few days after I picked up the car I noticed that there was still a very faint shadow where the stripes had been, but you could only see them in certain light. They appeared black on the black car, and it was an effect that didn't bother me.
What I didn't like was that at one end, right below where the stripes had been, there appeared to be 4 or 5, three inch long drip marks, either from a solvent that had been used, or possibly from some type of polish that the dealer put on the car. I had tried Dawn, and a very weak IPA solution, but neither one made a dent in the marks.
The M205 on the orange pad took the drip marks right off the car. I couldn't see that it removed any of the pin stripe shadow, and it didn't really do much for the swirls, but the marks that stood out the most to me were finally gone.
Since I didn't feel that I was making much progress I got out the M105 and a fresh orange pad. Primed it and did 6 section passes. Could barely wipe it off, and where I could, I still couldn't see much change. I did another 6 section passes, after adding a few drops to the pad, and I'll bet it took longer to wipe it off than it did to do the passes. Possibly fewer swirls, but I didn't know how many times I should go over the same section, and struggle to wipe off the polish, so I called it quits for the day.
Obviously I'm doing something wrong. The car hadn't been driven so the hood wasn't warm, and although it was starting to get hot outside, I was in the garage where it wasn't that uncomfortable.
I went through the entire trouble shooting guide, and not using the correct amount of product might be my biggest issue. I never even got to the "cleaning pads enough" stage since I only did 2 passes with each pad, and maybe I should have done more.
The one positive from today is that I never forgot to keep the pad in contact with the paint when turning on or off the DA. At this point, I'll take whatever success I can get.
I'm not opposed to trying this again, especially while the car is clean, and I'll take whatever suggestions I can get.
I'm also thinking that I can watch a hundred videos and read a thousand posts, but it could be even more helpful if there was a skilled detailer/forum member in the Dallas area who wouldn't mind taking a look at the car and my technique. I've now read enough to know that every car, and every situation, is different, and someone who's done this for awhile might be able to share some expertise in person that would save me a lot of trial and error. Just a thought ....
