pricha00
- May 4, 2007
- 296
I just started using my new 4 inch CCS pads to polish some of my vehicle. I was using the orange pad with XMT 3 and a white pad with XMT 1. I did the front fender first with no issues. Being the lazy bugger that I am, I then tried the 4 inch pads on the hood. The Rav4 is not exactly a large vehicle but the hood is one of the areas that actually can use the 6.5 inch pads but I was too lazy to change the backing plate so away we go with the 4 inch. No problem on first half of the hood but the second half different story. I thought the pad looked a little funny during the polishing but I didn't stop until the polish was broken down. I then found that the center of the pad was extra warm and it seemed like the foam and disappeared from the center of the pad. There was no spongeness at all when I pressed the center area. The spongeness did return after I removed the pad and let it sit for like 10 minutes to cool down. I was applying no pressure to this pad, just the weight of the UDM. Did I screw up? I noticed a little blue goo left on the center of the backing plate velcro as well. Is that the glue from the pad? Should I just chuck the pad or clean it and see what happens? I did order two of each 4 inch so I have a extra one anyways. I finished the area off with the white 4 inch and applied the XMT glaze with the 6.5. Looks great in my opinion. Black is a pain but boy does it look nice when swirl free!!!!!!
Pat.
Pat.
