sportflyer
- Jan 14, 2017
- 5
What the difference between the two Optimum No Rinse products W&S and W&W ? Is one easier to use than the other? Tks
Simply put, ONRW&W has a wax component in it whereas the normal blue ONR does not. I`v had a few Optimum "leaders" recommend ONRW&W for maintanence washes and the blue ONR for everything else. Personally, I stick to the normal blue ONR. If I want a wax component added, Ill use a spray wax or similar as I dry.
OK. I understand. I will just use the blue ONR for washing.
Last week was the first time I used ONR . I used it in the garage when the temperature was 40 deg F.
I sprayed each panel with ONR at QD concentration before washing with regular concentration . It works very well but now I am wondering whether the pre spray is really necessary .
QD strength isn't necessary for a pre-rinse.
Fill a bucket with 2 gallons of water and pour 1 oz of ONR in. Just fill your bottle from that and you will have 1:256 rinseless ratio.
I'll admit I use 1 ounce in a gallon pump sprayer, so 1:128 for me.
Good point about using wash concentration for a spray pre rinse .
As for usage , I find that I use less the 1/2 the ONR wash solution for 2 cars over 2 days. I wash only one car per day . I also find that using 2 rinse buckets is most helpful , the first one with dirt guard , the second just plain water. 2 rinses keep the cleaning mitts much cleaner before dipping in the ONR. I find it faster to use 3 wash mitts .
One other interesting observation is that the car appears to be less messy from road splash when driving through snow and slush after being washed with ONR ...More slick so the splashes wont stick as much ? Maybe I should keep my unused ONR in the wash bucket for a quick wipe down of the lower panels of the car after a run in messy road conditions rather than throw it away.
You can pretty much keep your wash media in the unused ONR in the wash bucket. No need to throw it away unless you need to throw it away. I think a lot of the guys who use ONR just keep the BRS in the ONR solution until next time they need it. And like the others have said above, no need for a rinse bucket with ONR. You would be surprised at what you could get away with when you use ONR.
Check out the rag company you tube channel. Yvan Lacroix goes into good detail on ONR. He recommends one bucket. He also states that if using 2 buckets then both buckets should have ONR. It makes sense as he has stated before that the plain water from one bucket is introduced into the bucket of ONR which could dilute it even more.
Here is an example of the dirt that settles down at the bottom of the bucket after I had taken out the grit guard. The ONR itself is clear and the dirt clumps up at the bottom. I used this wash solution about 4-5 times. I could have used it for one more wash if there was more ONR solution that I could use with the big red sponge.
One additional thing I did was cut 1 inch off the legs of the grit guard. This allows me to have more access to the ONR solution. Thanks to Yvan for that tip.
This is true. I leave the BRS in the solution each time. I do clean out the BRS with APC every few washes. The gamma seal lid is a must for any rinseless wash.
Why cut one leg off of the grit guard. I'm not understanding that. I never tried the sponge method I use 10-12 microfibers per car, and my solution never gets dirty.
All the legs were cut not just one. It allows the grit guard to sit lower and allow access to more ONR solution than the typical height of the grit guard. I have moved strictly to the big red sponge when using ONR. The sponge is designed to pick up the dirt and it is released as it is agitated against the grit guard. With the BRS I am only using a handful of towels. Saves me from washing more towels than I need to and the sponge is always there when I need it.
I use the Lake Country version of the BRS, it's the same thing but blue basically. I find it works great for rinseless washes no matter the manufacturer. I do use a pad cleaning brush to go over it if I see that the sponge is not releasing dirt but I pretty much never have issues with any dirt retention and I've abused ONR to the point where on one of my cars that's a dark blue and has been corrected and coated, I'll drop towels and the wash sponge onto the ground and keep using those to wash and no issues so far. Rinseless technology nowadays is honestly quite amazing. I did this because I didn't believe Optimums claims quite frankly, and I actually will add a clump of soil from the lawn into the wash solution and then wash my car with that. So while fresh microfiber towels are a great technique, you can pretty much use any type of rinseless wash media you want whether it's sponge or wash mitt.
If I'm using ONR I dry with a griots pfm and opti seal. It's an amazing combo.How are you guys drying your car with onr, is it best to dry with damp microfiber, damp waffle weave, or dry waffle weave/microfiber with xpress as drying aid?
