Since I never learn how to do wet-sanding, I was wondering if a heavy compound can give the same result as a wet-sand !?
Let say, a wet-sanding will remove 15 microns, with 2 pass of SSR3 I can also remove 15 microns. would the result be the same ? can the correction be the same ? i.e: correcting orange peel.
