Different Polish on same pad?
astrob0y
I only have one white pad, I'm not sure whether to use XMT #1 or #2. If i test with #1 and its not strong enough can i just use #2 on the same pad without washing it? Just want to make sure there won't be any side effects. Thanks :)
You should be ok, but I would at least spur the pad first.
Buy more Pads - Mixing two products even ones that close on the same Pad is a NO NO. You are starting Down a slippery slope to shortcuts of slopiness when you do that ! :-)
Probably not the most accepted practice but I've never hesitated to go up in aggressiveness on the same pad. I've never gone from more cut to less cut on the same pad without cleaning first. Just do what Rsurfer said and you're good to go.
Thanks for the fast replies guys, in this case I'm going up in cuts so i should be fine :).
