LuxuryAutoSpa
- Jan 8, 2012
- 120
Hey Mike,
I have a question that i just seem to not be able to answer myself and i Need Feed back please.
My situation is I have step into the arena of doing Semi Trucks, I have been doing them since june of this year by the good ol fashion way of brush, soap and water. I must say i have been doing a dang on good job. I am fully aware that i am doing this the hard way.
Anyway to get to my question i have a dewalt 3000 psi, 2.5 gpm and a 50 foot hose, my factory installed chemical injector that gives a 10 to 1 dilution ratio. The chemical that i am using needs to be applied at 40 or 50 to 1 ratio. I am not a math wiz and this is where it gets confusing,:surrender: i know i can mix the chemical to 50 to 1 , but the pressure washer is still going to dilute it's 10 to 1 ratio. So what should be the correct mixture i need to premix (ratio) should i dilute to, to make up for the pressure washer spitting out a 10 to 1.....and take in mind the 50ft hose...Math wiz and human calculator please help :work:
