Setec Astronomy
- Aug 31, 2010
- 17,175
- 1,469
How do you guys feel about directional tires? Other than winter tires, I've only had one set, and that was a long, long time ago.
I've never liked directionals because you can't rotate them in an X-pattern, which I like to do to even out wear. With winter tires, it's just the way it is and they generally aren't on the car that long.
That being said, my now defunct high-end tire shop, refused to rotate in an X-pattern, but I think that was driven more by a desire for no comebacks due to possible vibration from spinning the tires in the opposite direction (he also insisted on doing a balance, for at least the fronts, during a rotation, I'm presuming for the same no-comeback reasoning--it was a small shop and comebacks likely disrupted his tight scheduling, I could only get him to fix a flat right away if I brought it to him off the car).
So what's your view on directional tires? (and I guess on rotation, since that's my reason for not liking them)
EDIT: Thinking about this after I posted, the reason I have always done X-pattern rotation is that is the manufacturer recommendation for every car I've ever had, and it makes sense to me why they recommend that.
