disinfect interior?
sito
what do you guys use to disinfect interior ?
do you use bleach, vinegar?
I have to clean steering wheel, door handles, shifters.
Using steam to disinfect might be kind of risky considering it needs to be left in the same spot for 5sec. in order for steam to "disinfect"
I have a cheap ozone generator from ebay (~70$) that does a stellar job at removing odors and killing bacteria. I put it in for an hour with a window cracked 1/2" and voilà. That and an interior cleaner and your done imo.
Sent from my SM-G930W8 using Tapatalk
Or, why bother disinfecting. Different bacteria will come back to replace whatever you killed. That said I have used scrubbing bubbles on interior plastics without harming them.
I usually don't worry about disinfecting unless there is a specific area or issue. Had a BMW last week that a cat got into but couldn't get out of for a couple days. Used the right rear floor for his litter pan. Really NASTY odors there! Soaked with a commercial disinfectant (ZEP Antibacterial Disinfectant) blotted up with towle, Sprayed down with an enzymatic cleaner, extract, reapply disinfectant, extract again, ozone aimed at the area for 45 minutes, reapply disinfectant, air dry. Odor totalt gone, VERY happy customer. Don't forget yor PPE (gloves, mask, ect..)
But typical interior work, I don't worry about disinfecting.
Mike
I used to rent a lot of cars during business travel and the interiors were usually pretty gross. I would use Lysol disinfecting wipes on steering wheel, dashboard controls, console and door arm rest. I have never used them on a personal vehicle and I would be hesitant to use anything with bleach. I have used rubbing alcohol on my dashboard controls followed up quickly with Meguiras Interior Detailer.
I often wonder what the disinfecting capabilities are of various cleaners like diluted waterless/rinseless washes and APCs.
I would think most cleaners would disinfect to some extent, but is a clean surface the same as a disinfected surface?
I also "clean", but not intentionally "disinfect".
Zero.
No "cleaner" can make disinfectant claims without backing it up. And what backing it up means is it has to be registered with the EPA as a disinfectant and prove it's claims, and that costs big $$$.
I work for one of the largest distributors of cleaning chemicals in the country. I just finished attending our annual trade show with over 400 vendors in Orlando 2 hours ago. All the top chemical manufacturers were there, P & G, 3M, Clorox, SC Johnson etc. Hospitals are a huge part of our business so I regularly attend training on the newest disinfectants, kills times etc and nasty stuff I don't care to think about. LOL.
The most important part of truly disinfecting anything is contact time and the bugs you are trying to kill.
If someone did request it you could up charge for it.
I have done like posted above with enzyme cleaners for special situations. Two crab basket spills and pet situations.
Question, are enzyme cleaners appropriate for cleaning up vomit?
I don't think it would be zero, but certainly not the 98.9% or whatever some disinfectants claim.
And I would assume a somewhat caustic APC at 10:1, or vinegar at the same would provide the common human a "clean enough" surface.
I wouldn't think a waterless or rinseless would not do much, although I wouldn't be surprised if D114 would have a reasonably high percentage if it were tested.
I'm not trying to kill Mersa here.
Odoban can be used as a disinfectant and would likely be safe on car surfaces. However, I haven't tested it that way. I have used it on carpet, blankets, clothers and interior paint without any damage,
Spray Nine is a APC that disinfects. I have used it to kill mold in the past also.
Cleans, degreases and disinfects like a pro.
Kills viruses, bacteria and fungus fast.
Deodorizes and eliminates dirt, grime and stains.
Works on vinyl, plastic, fiberglass and stainless steel.
It is actually a fantastic APC if you've never tried. It will remove wax/sealant on exterior paint in my opinion as a prep wash.
I have OCD. I can't tolerate bacteria build up during car ride. I have the urge to clean steering wheel, shifter, door handles, window buttons.
Why can't I use vinegar?
Spray Nine is the company name they have a lot of products.
They have 5 digit product numbers on their website and tons of different products, that is needed to correctly identify the product and sds sheet.
For example from the website US Part Number: 87732
You're in my world E2K LOL.
I know I was just kidding.
I just use Clorox wipes. They are bleach free but kill 99.999% of bacteria
Used them many times on our own cars. Can follow up with product of your choice after if you wish
