St.LightDetails
- Aug 7, 2013
- 33
So I've been living with this nasty clear-coat failure on the front bumper of my truck. Looks like it failed after the previous owner had fender bender and cracked the paint. It wasn't nearly as bad when I bought the truck but has been progressively spreading. So today I decided to tackle the issue. Granted this was outside not in a protected paint booth so keep this in mind if you have a garage that is climate controlled your results could be even better.
Also for some reason I cannot get the before pictures to load it says they are there but I can see them. I'll work on getting them up.
All you need to tackle something like this is some sand paper I used 180 for initial sanding of the paint and then 1000, 1500, 2500 for wet sanding. Then you're going to need some paint I went to AZ picked up the dupli-color that matched my truck and some of their clear-coat. Some masking tape and some old newspaper
[/IMG]
Sand down the clear coat that's failed making sure that you get all of the clear around the edges and any of the subsequent base coat that is bad as well. Make sure to "Feather out" your edges. This means making sure that when your sanding there won't be any uneven spots you will see in the paint.
When your sanding it should look something like this, you can also get a spray bottle of water and a old microfiber to wipe away the dust so you can really see how its going. As you can see in the above picture more sanding needs to be done to get all those cracks out.
[/url][/IMG]
This is after sanding is complete and the truck has been taped off. In retrospect I should have given myself more room to blend the paint in and had to move my tap line over to about mid-way under the head lamp after looking at it. Took a little extra time but worth it. When you're painting make sure that you do not paint all the way to the tape. Start spraying before you get close the paint and lift up well before the tape line. This way the new paint will blend more evenly with the existing color on the car.
[/IMG]
Hand polished after wet sanding. Again for some reason shots from further back not uploading. Says they are there but I cannot see them. Hope this helps!:xyxthumbs:
