I found some videos on youtube of guys with semi trucks, farm equipment, school bus, etc.. They were using foam guns and pressure washers to clean the vehicles with no scrubbing required. Using normal car wash soap of even foam cannon specific soap will usually leave behind a film or stuck on bugs. But the chemicals these guys were using on the farm trucks is probably a bit stronger. The main one I remember was called Zep Truck and Trailer wash. The product page claims no scrubbing is required. It got me thinking, why not just use that stuff literally every day or every other day to keep the car always looking fresh?
Just foam it up, pressure wash off, then use a powerful leaf blower to dry. Pat down whatever remaining water is on the paint (pat dry, dont wipe) and your done in about 15 minutes.
I know, some will be concerned about such a harsh product stripping off the paint protection. But honestly, if its getting washed literally every day or two, I dont think things will have time to damage the clear coat. You would also get the advantage of never having to touch the paint or put in physical effort. The paint should get touched as little as possible.
Obviously this method isnt meant for show cars, and its not gonna be as thorough as a real hand wash. But for daily drivers, this may be a good way to keep your car swirl free and always appearing clean while spending as little time as possible. Just get paint correction done, then never touch the car again.
Im sure there is some stuff still left on the paint. However, scratching the paint during the drying process shouldn't be an issue with the correct leaf blower and patting dry method.
Seems like this could work better for a daily driver vs. letting the car get filthy thought the week then touching the paint every weekend.
