Do I really need acid based Wheel cleaner?
ch17
Hi
I have a question in my mind
do those alkaline degrease that contain Sodium hydroxide, potassium hydroxide, "butyl", etc.. anything strong alkaline able to attack rust iron that appeared as brake dust for easier removal?
I found myself having a hard time removed caked brake dust completely with those alkaline based degreasers even at strong dilution compared to using acidic wheel cleaner, such as Oxalic acid(not a fan of smelly acid variant)
I have a question exactly what kinds of wheels can you safely use an acid based wheel cleaner on?
Polished aluminum (no clear coat) and damaged clear coated wheels, as the acid can get under the damage and lift the clear or color coat.
He asked which wheels can an acid based wheels cleaner safely be used on. Those examples are the types of wheels you should Not use an acid based wheel cleaner on.
Would that not mean you can use it on all others?
You can use an acid based wheel cleaner on all modern day factory OEM wheels.
Hi
•Those strong base cleaners are very
tough on grease, but won't touch rust.
•Sounds like using one of the products
labeled as being iron-removers/dissolvers
(“the bleeders”, as it were) would likely
be one of your best options for this task.
-Here is a good starting point:
Search
I like mckees foaming gel wheel cleaner so much I bought the gallon size. But you have to remember you should only need this type of cleaner every few months. In between you should be able to keep it clean with car soap as long as you have some decent protection on there.
Search
Thanks Bob!
you have answered my question precisely.
No wonder my OPC did nothing to those embedded rusts. always find some around the nook and cranny even after 2 passes of power clean and agitated with tire brush. I am quite sure I cleaned them
look like I could not avoid having an acidic cleaner clean my wheel.
Was thinking whether I could get away with a good degreaser/APC instead of buying multiple products
