do you have to clay bar b4 every wax?
DiSpLiFF
i know its good to use claybar before waxing, but do you have to use it every time?
if washing doesn't take off old wax, is there anyhting that does?
After washing your car or wiping it clean, you use you clean hand to feel the paint and check for above surface bonded contaminants and if discovered then you would clay the paint.
Claying removes most all the wax off the surface so if you clay you should always build-in the time to at a minimum re-wax the vehicle.
If you want to strip off the old wax to lay down a fresh coat you can do this by using any mild paint cleaner or cleaner/polish.
If you do this often then maybe consider using a good quality cleaner/wax.
get a plastic bag and put your hand in it. Run your hand over the paint and if it feels rough then you should clay. To remove all old wax there is stronger soap you can buy, paint cleaner, or you can do an IPA wipedown
IPA=Iso alcohol and water mix
Good advice from the guys above but once you've clayed your car you won't have to do it very often. I probably average twice a year on mine.
Claying will remove old wax, but the purpose of claying is to remove embedded contamination that normal washing just does not remove.
If you want to prep your paint for new wax/sealant that doesn't have any cleaners, I suggest a wipe-down with Isopropyl Alcohol (IPA). Just use a quality microfiber towel and spray and wipe down the paint as if you were using a quick detailer. That will remove all of the existing paint protection and will allow the wax to bond to the surface nicely.
You can even mix the IPA 50/50 with water and it will still easily remove all the wax. You don't have to do it, but diluting it will not use as much alcohol and will get the job done just fine.
thanks for the quick responses :xyxthumbs: appreciate the help
how often does everyone wax their car?
Will IPA damage the clear coat? Probably a stupid question, but I've never used it.
No, no damage to the clearcoat. Just removes all the waxes and leaves the paint LSP ready
So if I want to re-polish the car before winter would these steps be appropiate?
1. wash car
2. IPA (to remove the old wax
3. Polish to remove swirls
4. IPA ( to remove polish residue)
5. Glaze
6. wax
DisPliff, I really enjoy waxing my car so I like to wax every week or every other week. It's completely unnecessary but I enjoy it and choose to do it frequently. After around a month or two, I like to do an alcohol wipe-down and start all over again. I can't seem to stick with one combination for very long because there are so many good sealants and waxes out there !!
Billd, your method looks great.
1. wash car
5. Glaze
6. wax
Yes. I would make your step 6 as "seal" than add step 7 "wax" but that's just me.
Regards,
GEWB
where do you purchase the IPA? can i get it from a place like canadian tire? or just drug stores
Re: do you have to clay bar b4 every wax?
Yes, just drug stores or wal-mart, etc. Those tend to be the cheapest place to purchase the IPA from.
If you have/want to do a light claying before waxing again then use Pinnacle detail clay as its the softest and designed more so for that and not a full normal clay job.
Here's an anecdote about claying.
My neighbor and his wife each own a Mini.
Her car stays in the garage and is driven maybe 70 miles a week.
His car is parked outside and driven 400 miles a week. And it gets parked under a sap dripping pine tree.
Her car is fine with a once a year clay and twice a year wax.
His car needs to be clayed every other week and gets washed and waxed every Saturday morning. Any less and the sap would eat through the wax and damage the paint. And he goes through a bar of clay every two months.
But his wife loves that damn tree.
As mentioned in another thread about microfibers, after drying go over your car with a mf buffing towel if fibers come off time to clay the car :)
