I have been using it dry and I don't know if that is correct.
That's fine, won't mar. I usually spray with either 425, AW, or DP Final Gloss) to lubricate and give extra pop.
I found when using a QD as a lub to wipe with the guzzler, it does affect the absorbency of the ww. Be sure to wash your ww after every use.Makes mental note to try this when I wash the car later this week.
THX for the tip!
ALWAYS! Then wring it out and you are good to dry.I have been using it dry and I don't know if that is correct.
