Do you Remove your Bucket Grit Inserts Each and Every Time ?
I do when I was running the CG ones, and prior to that, the OG Grit Guard
I have the Detail Guards + Scrub Wall. It's a pretty SNUG fit. Snug enough that I need to push down on it to bottom out.
It's going to be a slight exercise weekly after a wash to pull it out, and I expect this is going to at least put stress on either the rubber feet of the Detail Guard or accelerated - stress- on the plastic locking legs doing this 1X a week (aka, every car wash). Just swapped grit guards in my buckets to new ones and it has me thinking.....
Resolved the issue.DG Version 1 of these -----there were posts about it floating:not staying in place
Version 2 of these....the removed the foam side pads and added rubber ones.
I took the rubber feet of and the tension is all gone, minus about 2 inches before it needs to bottom out
It is fine ....I don't expect it to float, I believe partially due to the fact that the scrub wall is still tensioned against the side of the bucket.
I haven't filled it with water to confirm but it feels pretty well tensioned
