Dodge Neon Extreme Makeover with Dodo Juice
This is an example of a KISS Detail
KISS Detail = Keep It Simple Simon Detail
A common tendency I see when people are new to detailing, especially with an inclination to start detailing part time for money is they tend to get caught up in the idea of doing multiple-step procedures like you would with a show car, or special interest car.
Nothing wrong with that especially if you're new to detailing and you need to get experience doing multiple-step procedures but when it comes to a daily driver, in order to make the customer happy and also make a profit you need to keep it simple and consider using a one-step cleaner/wax.
Your exterior process would like like this,
Wash
Clay if needed
Apply a one-step cleaner/wax - By hand or machine
Dress tires
Clean glass
That's about a basic as you can get when it comes to a simple exterior package.
In the below example, I met Chris, the owner of the extremely oxidized blue Dodge Neon, in the parking lot of a local grocery store and after starting a conversation with him about the condition of the paint on his car, invited him down to the studio to do an extreme makeover.
2-3 years ago Chris purchased this used car for simple transportation to and from work so his nice car could remain in excellent condition parked safe in the garage. He purchased a popular brand car wax at the local auto parts store and applied it according to the directions on the label on the can. He told me the results weren't that great so he figured it was the paint and since that time has not even washed the car again.
The pictures below show what can be done using a simple process with only a few products and is a great example of taking a car's finish to it's maximum potential using only a one-step cleaner/wax.
This car has been re-painted using what appears to be a low quality single stage paint and exposure to the cruel Florida weather plus a lack of maintenance has left the paint extremely oxidized.
I told Chris he would have to help me and by helping out he would have the opportunity to learn how to machine polish. I also snagged Nick, an employee here at Autogeek to help speed up the process. It took the 3 of us approximately 3 hours from start to finish and it would have been faster had we not taken the time to tape-off the car down the middle and take before and after shots of the results.
Without further ado, here are the pictures...
For this project I chose Dodo Juice products since they offer a one-step cleaner wax that can be applied by hand or machine. We used the Griot's, Meguiar's and Porter Cable DA Polishers.
The paint was so oxidized that we went over it twice with the cleaner/wax, once with a Lake Country 5.5" CCS Orange Light Cutting Pad and then a second time using a Lake Country 5.5" CCS Green Polishing Pad and then we applied the Topper using a Lake Country 5.5" CCS Gray Finishing Pad.
The orange light cutting pad with the Need for Speed Cleaner/wax was very effective at removing the oxidation but it was leaving a haze in the paint so we re-buffed using the green polishing pads which removed the haze. A person could have used just the polishing pad and spend more time removing the oxidation but we chose to use the more aggressive cutting pad to really get in there and chop out the dead oxidized paint and once the dead, oxidized paint was removed, removing the haze using the polishing pad went fast...
Anytime you're working on extremely neglected paint, a good practice is to use your choice of product heavy or wet, this means be sure to use plenty of product, especially for the first step as in this case the dried-out, oxidized paint was soaking up some of the liquid wax as we worked it against the surface.
Ample and even extra product in an example like this also helps to keep the surface lubricated for good pad rotating which means good cleaning or abrading action.
We applied the Need for Speed Cleaner Wax on the 6.0 speed setting with the cutting pad, on the 5.0 speed setting with the polishing pad and on the 4.0 speed setting for the stick wax with the gray finishing pad.
Dodo Juice Need For Speed Cleaner Wax and Dodo Juice Supernatural Wax in stick form plus DA Polishers and Lake Country 5.5" CCS Pads.
Severe oxidation
Using the Pro Blend Bottle Proportioner to measure out the DP Rinseless Wash and Gloss
Here's Chris using the Porter Cable to remove dead, oxidized paint using Need For Speed Cleaner Wax. This was the first time Chris has ever used a machine to polish paint.
"Each one teach one"
Here's Nick tackling the vertical panels which while oxidized, required a lot less work to restore than the horizontal panels.
This is me using the Clean your Pad on the Fly Technique to clean my pad on the fly as we removed the oxidation off this Neon.
After the oxidation was removed we topped the Need for Speed using a finishing wax for more protection and to bring the appearance quality up a tick higher.
Half the car is finished, we're just waiting for the wax to set-up before we wipe it off and then take some pictures.
Continued...
Here's the before and after, side-by-side results...
Here we've flipped the car around to do the other side...
In the below pictures you can see RIDS or Random Isolated Deeper Scratches.
Where I'm pointing you can see the reflection of the overhead florescent lights on the 'after' side...
The before side is as flat as chalk and there is absolutely no shine or depth to the finish...
Time to knock out the passenger side...
After removing the oxidation and applying the Dodo Juice Supernatural Wax which is available in stick form to make machine application easier.
Simple, fast and effective.
This isn't a show car and we didn't use a show car process on it, we kept it simple on purpose but the results are still dramatic and impressive.
Nicely done! :props:
Did you do anything to the headlights? They look clearer in the after photos.
That is the true art of detailing when you take take oxidized paint to glowing paint!
Those are some awesome 50/50 shots. Most people would think the paint on that car was beyond repair. Great job. :xyxthumbs:
how did the paint look up close?
i have noticed that when removing heavy oxidation that the paint even after removing the oxidation from the surface still has a haze to it. Possibly from the reaction of the paint with various things but using a simple cleaner in my cases didnt restore shine very well. it was shiny, but if you looked at it from the right angle you could see this strange haze. using a more aggressive product corrected this.
have you experienced this?
The transformation is so dramatic that many would think that the car was painted.
Wow! Those are some pretty amazing results. I didn't realize how much you could do with a 1-step cleaner wax.
Any tips for getting into cracks & crevices, like where bumper fascia meets side panel, or the groove along the body-side moulding?
An amazing detail. Wish you'd hang out in my supermarket parking lot, Mike!
Excellent job Mike! I'm certain the owner was pleased! I really hope PJ stops in to see this thread.
Most places it was pretty clear, the horizontal surfaces were the worst but they still came out very good.
If a person wanted a higher degree of perfection and their customer was willing to pay more for a more complex process then a dedicated compound or polish would create better results. For very fast detail, and I mean fast when you don't include taping off, washing and drying the panels, doing some "instruction" etc., the results were very good and now Chris knows how to machine polish.
Agree. We could have done a lot of things but this car is a daily driver and will be parked outside all the time, getting it "good" was the goal although hitting it with a true compound would have chewed off a lot more of the dead paint faster and really smoothed the paint out.
One thing I would note was this appears to be a very in-expensive paint job. Chris bought it this way, he didn't have it painted. In-expensive is my way of typing the word cheap.
I was hoping we could have just hit it once and then topped it but the paint reacted like it was soft and thus the cutting pad was leaving a haze. Doing a 'quick' second pass with a less aggressive pad removed the haze and left the paint clear and with a coat of wax already laid down. The topping wax built off these results and amped up the gloss and clarity a tick.
Any tips for getting into cracks & crevices, like where bumper fascia meets side panel, or the groove along the body-side molding?
No.
Actually, "no" in that there's no way to ever make machine cleaning, polishing and waxing these areas you bring up fast and easy.
The rubber and plastic trim was dried out just like the paint and a sponge for absorbing anything put onto it so if the car "you're" detailing is important to you then tape off the rubber and plastic trim so you don't stain it white.
We skipped that step because as already stated... this is a daily driver that will be parked outside the rest of it's life and likely go down hill from this day forward unless Chris decides to maintain it.
Actually was picking up dry cleaning and spotted this Corvette in dire need of an extreme makeover,
Looks good from this angle...
Needs a little help from this angle...
After talking to Dan, the owner of the Corvette, I spied the Neon and struck up a conversation with Chris, the goal was getting the Corvette for a project, the Neon was a just in the right place at the right time.
The Corvette is worthy of a multiple-step process.
After what you did to the Mustang, I can't wait to see this one! :hungry:
WOW really big difference between the before and after!!
Dodo Juice Need for speed is, indeed, a great product!
I cringed when I saw the Corvette. That is very painful! :eek:
Wow! That Neon was absolutely trashed with oxidation. Fantastic results bringing it back.
The only thing of a comment is that if I was doing this as a daily driver, I would never use Supernatural. It's just too expensive and a boutique wax. I probably would have used a synthetic product for a daily driver but the transformation is still freakin' awesome!!!!!!!!!!!
Another great write up. this is what detailing is all about - the turnaround. i know, even i, will walk around and look for the minor swirls in the show cars... but the truly good jobs are the ones that really transform. and there, Mr Phillips you take the cake.
present and accounted for buddy 8)
Point taken but I was trying to keep the wax related portions of this project with a Dodo Theme...
Plus, I'm a big fan of doing EVERYTHING by machine whenever possible so it was only supernatural to use the Supernatural as intended and that's via machine application.
:dblthumb2:
