dodo juice red mist tropical detailer
PA DETAILER
the MOTHER of all detailers? could very well be. i always had this in my arsenal. the canyon only needed a wipe down this morning after yesterdays wash/detail. it did not move. when i was finished, i grabbed the RMTD for something different. i forgot what a insane product this is. you use very little. just one fine spray per panel. spread with mf, and your done. flashes off great. no streaks. and leaves a insane shine. i love my DP FINAL GLOSS. but RMTD is on top of the food chain of detailers. and of course i will continue to use DP FG. after talking to dodo, they said the secret of TRMD is that its really more of a sealant.
on a side note i see CC released a new hybrid detail spray/sealant. HYBRID V7.
You know Dave, I've never tried any of the Dodo like of products and I might just have to give this a try....:props:
it would be a good choice to introduce you to their line. :xyxthumbs:
Leaves a great shine that is slick also. Only downside is it sometimes doesn't remove all the water spots after washing like a QD does. I QD after washing then use the Red Mist. Like a dodo products, a little goes a long way.
Its great indeed ... just use very sparingly. It seems quite concentrated like most their product line.
DJRMT is my favorite gloss QD. Take into consideration it is not made for cleaning at all, just add shine, so it won't help much for water spots or bird droppings.
Red mist was in a class of it's own ...until I discovered Reload by Carpro. It's the new super spray on sealant in my view. The only negative is that it has a really strong odor and it's not pleasant.
It does have a strong odor, smells like a beach with all the coconut oils. I like the smell, but smell is subjective.
the sprayer broke on my red mist, it will not spray. Still really great gloss and slick feel. i like the smell too! coconut and pineapple mm sweet
It is a great spray sealant, I just use it sparingly because of the price. Does it work as a drying aid?
Silverfox mentioned using Reload in a manner like Tropical Red Mist. My understanding is that Reload needs to be applied either to a clean surface or as a booster to CQuartz (or to Reload itself). It definitely should not be applied over wax. Please correct me if I am wrong.
I apply Red Mist to a MF towel and the wipe it on...going sparingly.
Also, it contains solvents (it's not water based), so make sure the wax or sealant is well cured before using.
I believe Dodo has gone to a more conventional sprayer. I replaced mine with a typical spray head and it works fine.
It is a nice product....similar to Z8 in performance, IMO.
Was disapointed that it had no cleaning power..... Shine was fine
