Have tried Dodo's Acrylic Spritz (DAS).
I applied it to a clean surface a couple ways:
1. I primed an MF pad with a couple sprays then did two short sprays per panel, spread it with the MF pad and then immediately buffed. I also tried doing two panels (so the first one had a few seconds to dry/haze). Either way it buffed right off and looked great and slick.
2. I applied it like a QD (to a clean surface) with an MF towel....spray, spread, buff.
DAS flashes off (like CG's HV7), so it's very easy with no streaking.
It's a very nice product and may semi replace my Red Mist. DAS is water based whereas RM is solvent based. Either one is great.
