Super Degreaser
Meguiar's Super Degreaser exceeds expectations by quickly breaking down even the toughest grease. Its fast acting, free rinsing formula prevents unsightly white residue stains while its herbal fragrance creates a pleasant work environment.
D-10801 1 gallon
D-10805 5 gallon
D-10855 55 gallon
· Medium Duty Degreasing 10:1
· Heavy Duty Degreasing 4:1
[FONT="]
[/FONT]
Safe D-Greaser
Today's vehicles utilize a variety of specialized materials, which is why Meguiar's Safe D-Greaser has been specially formulated to reduce the possibility of staining exterior surfaces. Designed to quickly break down grease and grime on engines, tries and fender wells, Safe D-Greaser is ideally suited for today's fast paces, high volume shops.
D-10501 1 gallon
D-10505 5 gallon
D-10555 55 gallon
Dewaxing 20:1
Recommended replacement for regular All Purpose Cleaner and Citri-Gel Multi Cleaner.
All Purpose Cleaner
Meguiar's All Purpose Cleaner is ideal for reconditioning interior surfaces. The superior foaming action gently lifts the dirt away while its unique blend of fabric softeners and optical brighteners enhance the look and feel of carpet, upholstery, vinyl and even leather.
D-10101 1 gallon
D-10105 5 gallon
D-10155 55 gallon
Recommended replacement for All Purpose Cleaner +.
[FONT="]
[/FONT]
Hyper-Wash
Typical dilution rates are obsolete when comparing them with Meguiar's Hyper-Wash. Using innovative techniques Meguiar's has created a product that produces rich, stable foam at an unbelievable dilution rate of 400:1 (yes 400 that is NOT a typo). Its biodegradable formula safely and effectively lifts dirt and grime off all surfaces.
D-11001 1 gallon
D-11005 5 gallon
Dilution 400:1
Recommended replacement for Car Wash Soap.
Shampoo Plus
Meguiar's Shampoo Plus lubricating formula and luxurious foam team up to gently clean and condition even the most delicate clear coat surface without scratching. Its conditioning formula deepens gloss, boost shine and leaves a highly reflective, slick surface making it the perfect choice for the ultimate car wash.
D-11101 1 gallon
D-11105 5 gallon
D-11155 55 gallon
Dilution 10:1
Recommended replacement for Wash 'n Wax.
Glass Cleaner Concentrate
Meguiar's Glass Cleaner Concentrate easily and consistently removes tough vinyl fog residue, road grime, smoker's film and bug splatter, producing crystal clear glass. For every concentrated gallon, you get eleven ready-to-use gallons of glass cleaner.
D-12001 1 gallon
D-12005 5 gallon
Dilution 10:1
Wheel Brightener
Meguiar's Wheel Brightener is the product of choice for professionals looking for a powerful wheel cleaner that quickly and effectively removes tough brake dust. There is a thin line between effective cleaning and dangerous to use products. Wheel Brightener gives users the ultimate in flexibility, cleaning and safety with one product.
D-14001 1 gallon
D-14005 5 gallon
D-14055 55 gallon
Dilution Up to 4:1
Not for use on anodized, magnesium or polished aluminum wheels.
[FONT="]
[/FONT]
X-Press Liquid Wax
Meguiar’s X-Press Liquid Wax uses a unique blend of wax and polymer agents to produce deep, rich gloss with lasting protection. This formula provides ease of application and instant wipe-off, making it the perfect choice for any production environment where Meguiar's quality results are as essential as speed & efficiency.
D-15001 1 gallon
Ready to Use
Application hand, orbital, DA or Rotary
Recommended replacement for Express Wax.
Last Touch
Meguiar's Last Touch Spray Detailer produces incredible depth, shine and gloss. This spray-on, wipe-off product has a unique blend of polymeric lubricating agents that gently removes dust, fingerprints, smudges and other contaminates, leaving a flawless, showroom shine.
D-15501 1 gallon
D-15505 5 gallon
Ready to Use
It can be used as a lubricant for Meguiar's clay, dilute 1:1 for this application.
Recommended replacement for Final Detail
Body Solvent
Meguiar's Body Solvent changes the traditional method of removing tar, road grime, gum and other petroleum based substances. Instead of applying and scrubbing, its VOC compliant formula can now be sprayed on the surface, allowed to soak, penetrate and break down the contaminant, then wiped clean with ease.
D-13001 1 gallon
D-13005 5 gallon
Ready to Use
[FONT="]
[/FONT]
All Season Dressing
Meguiar's All Season Dressing is a VOC compliant formula that produces a deep, rich, long lasting shine on all exterior rubber and plastic surfaces. Old or new, weathered or worn. All Season Dressing will give you the desired results time after time.
D-16001 1 gallon
D-16005 5 gallon
D-16055 55 gallon
Ready to Use
Recommended replacement for S-Dressing.
Silicone-Free Dressing
Meguiar's Silicone-Free Dressing is the choice for professionals looking for a high performance dressing which can be used in any silicone sensitive environment. Its VOC compliant formula produces an incredibly deep, rich high gloss shine on all exterior rubber and plastic surfaces.
· D-16101 1 gallon
· D-16105 5 gallon
· Ready to Use
· Recommended replacement for Silicone Free Tire Dressing.
Hyper-Dressing
Until now, the industry average for diluting water based dressings has been one to one or ready-to-use. Meguiar's Hyper-Dressing dilutes up to four to one, varying the gloss from high to satin. One product, multiple uses...a winning combination for every professional and an industry first.
D-17001 1 gallon
D-17005 5 gallon
1:1 High Gloss
2:1 Medium Gloss
3:1 Satin Finish
4:1 Natural Shine
Recommended replacement for W-Dressing and Engine Kote.
Leather Cleaner & Conditioner
Meguiar's Leather Cleaner & Conditioner is expressly formulated to enhance the appearance of interior leather and vinyl surface. Specialized cleaning and conditioning agents are designed to safely clean and restore leather's original look and suppleness.
D-18001 1 gallon
Ready to Use
Optimum Power Clean
Optimum Power Clean™ is an all purpose cleaner that safely cleans your vehicle’s dirtiest surfaces. Remove bugs, brake dust, and oily grime when using Power Clean full strength. Dilute it to clean leather, vinyl, and plastics. Optimum Power Clean™ is an environmentally friendly, surface-safe cleaner that will leave your vehicle spotless!
Use full strength, Optimum Power Clean™ cleans and degreases the engine compartment, cleans wheels, and wheel wells. This sophisticated formula dissolves bugs and powers through brake dust and oil to clean your vehicle’s dirtiest parts.
Dilute Optimum Power Clean™ up to 3:1 to safely clean leather, vinyl, paint, and plastics. Remove old dash dressings and tough residues from interior panels. Wipe away spills and spots from leather seats. Special polymers and emulsifiers break down contaminants with minimal agitation.
