Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 7
I am sure this has been asked before and I apologize for it, but I have been watching a lot of videos on detailing and I am wondering if every beginner/home user needs a fancy $100+ DA buffer? Or does it really make the difference?
Good question, I'll give you my take.
Key word being,
Beginner/home user
If you're just doing this for your own cars and TIME is not an issue, that is you don't care how long it takes you to go from start to finish - then "no" you don't need a $200.00+ polisher. I myself wouldn't buy junk but that's just me.
I think the best deal for the "average person" is the Porter Cable 7424XP and I share why in this thread that popped up over the weekend.
Great deal on a Porter Cable. Now what?
The Porter Cable is a TANK of a tool. You can driver over it with a truck, pick it up and go back to work. It's a short stroke polisher at 8mm orbit stroke length. All you have to do to maximize it's potential is use a 5" backing plate and the right pads. Microfiber pads for heavy cutting and THIN foam pads for anything else.
I am looking at just doing some minor paint correction and polishing. Medium size cars.
I was looking at the Griot's 6" one because I found one half price on eBay but missed out on it. Now I am wondering if just getting a Ryobi 6" cordless orbital would do the job just fine.
I have not used a Ryobi for some time but here's the deal. In order for YOU to be EFFECTIVE when using ANY brand of free spinning random orbital polisher from the cheapest to the most expensive units on the market you MUST maintain pad rotation.
IF the pad is not rotating it's also not oscillating at least not oscillating enough to remove paint. Removing swirls and scratches is actually removing and thus LEVELING the paint. No pad rotation means you're simply wasting your time. And this is the major downside of any free spinning random orbital polisher.
It's too bad Griot's quit making the Griot's Garage 6" Random Orbital Polisher. I never liked the name because the "6" has or had nothing to do with the tool. It came with a 6" backing plate, which was also a mistake in my opinion and experience. It was a copy of the Porter Cable 7424 and thus it is a 8mm short stroke free spinning random orbital polisher with a ton more power than the Porter Cable unit. BUT - they are both great 8mm free spinning random orbital polishers when used with the right backing plates, pads, abrasive technology and of course technique.
Hope that helps...
And definitely check out the thread I posted to over the weekend and also check out the LINKS I shared in my replies.
:buffing:
